Connecting Kenwood TS-590s to the internet on an iMac?
Re: Connecting Kenwood TS-590s to the internet on an iMac?
If you can wait a few days, I've just ordered from a local distributor a new Mac Mini to help me test this and some other applications.
Normally you need only Java Runtime to run jAReC which Is built based on Java 1.8.x.
I intend to build an iOS version of Pocket RxTx too, but this will take time.
AH6GT
Post by AH6GT »
I have had a few other Mac users contact me, asking if I have resolved the issue. I am so glad you have ordered a new Mac!
I know that others will be excited to get your program working!
Evidently, there is a freeware logging program called jLog. This page is titled "RXTX for Mac OS X: http://jlog.org/rxtx-mac.html
Am I correct in thinking that this has nothing to do with Pocket RxTx?
-Aloha,
Konabob (AH6GT)
I've received the Mac Mini today, but I don't have time at all to take it out of the box till Thursday. I will need some accommodation too, as this will be my first MacOS system.
You're right, that site has nothing to do with my app, is just a communication protocol.
Let's take it step by step. I'll be back as soon as I will have some more info.
AH6GT
Post by AH6GT »
I hope you are enjoying you mini-Mac. Have you made any discoveries?
-Aloha from Hawaii.
AH6GT
Not yet tested. I have prepared the system to start porting Pocket RxTx on iOS.
I will test jAReC too in the following days and be back with the result.
Sorry for the delay.
I have tried this evening with a PL2303HX based USB/Serial module.
The following driver was required to be installed on the Mac Mini (Late 2014 with OSX ElCapitan):
http://www.prolific.com.tw/UserFiles/fi ... 151022.zip
After a system restart, the serial interface was available in jAReC.
I think you have a problem with your USB/Serial interface not being recognized by the system.
On which USB/Serial chip is based your interface?
I have tried with a CP2102 too, but I was not able yet to find the right drivers, so it does not work for the moment.
As stated in one of my previous messages, if the serial interface is recognized by the Java subsystem, then if will be visible in jAReC too.
Anyway, it seems to be a bug if running on a Mac: the TCP port and the serial port are not saved in the config file.
I will fix this in the next release.
Best regards,
AH6GT
Post by AH6GT »
Congratulations on the progress!
My TS-590S connects directly to my iMac using the USB cable. I am using the Silicon Labs driver that I mentioned earlier. I am able to control the radio and also send and receive audio between the radio and computer. (fldigi and WSJT-X for example).
I have also installed Virtual Box, and am able to run the Kenwood control software using Windows 7 on my iMac.
I am not using any external chipset.
-aloha,
Konabob (AH6GT)
Hi Konabob,
To better understand, even if is working with FLDIGI, is still unrecognized by jAReC?
Can you please check to see if you have in the system a device like this?
/dev/tty.usbserial
AH6GT
Post by AH6GT »
Here is a list I get using the Terminal Utility.
jAReC.jar does not recognize anything in the Serial Ports list.
Is it possible a problem with the 'path'?
KonabobDesktop:~ konabob$ ls -l /dev
total 0
crw------- 1 root wheel 13, 1 Jan 26 05:28 afsc_type5
crw------- 1 root wheel 8, 0 Jan 26 05:28 auditpipe
crw-r--r-- 1 root wheel 7, 3 Jan 26 05:28 auditsessions
crw------- 1 root wheel 19, 0 Jan 26 05:29 autofs
crw------- 1 root wheel 31, 0 Jan 26 05:29 autofs_control
crw-rw-rw- 1 root wheel 22, 0 Jan 26 05:29 autofs_homedirmounter
crw-rw-rw- 1 root wheel 21, 0 Jan 26 05:29 autofs_notrigger
crw-rw-rw- 1 root wheel 20, 0 Jan 26 05:29 autofs_nowait
crw------- 1 root wheel 23, 0 Jan 26 05:29 bpf0
crw------- 1 root wheel 23, 1 Jan 26 05:28 bpf1
crw------- 1 root wheel 23, 2 Jan 26 05:29 bpf2
crw------- 1 root wheel 23, 3 Jan 26 05:28 bpf3
crw------- 1 konabob staff 0, 0 Jan 26 05:29 console
crw-rw-rw- 1 root wheel 18, 1 Jan 26 05:29 cu.Bluetooth-Incoming-Port
crw-rw-rw- 1 root wheel 18, 43 Jan 26 15:55 cu.SLAB_USBtoUART
brw-r----- 1 root operator 1, 0 Jan 26 05:28 disk0
brw-r----- 1 root operator 1, 1 Jan 26 05:28 disk0s1
brw-r----- 1 root operator 1, 3 Jan 26 05:28 disk0s2
brw-r----- 1 root operator 1, 2 Jan 26 05:28 disk0s3
brw-r----- 1 root operator 1, 4 Jan 26 05:28 disk1
brw-r----- 1 root operator 1, 5 Jan 26 05:28 disk2
brw-r----- 1 root operator 1, 6 Jan 26 05:28 disk2s1
brw-r----- 1 root operator 1, 7 Jan 26 05:28 disk2s2
crw-rw-rw- 1 root wheel 24, 2 Jan 26 05:28 dtrace
crw-rw-rw- 1 root wheel 25, 0 Jan 26 05:28 dtracehelper
crw-rw-rw- 1 root wheel 0, 0 Jan 26 05:28 fbt
dr-xr-xr-x 1 root wheel 0 Jan 26 05:28 fd
crw-r--r-- 1 root wheel 10, 0 Jan 26 05:28 fsevents
crw-rw-rw- 1 root wheel 14, 12 Jan 26 05:29 io8log
cr--r--r-- 1 root wheel 14, 17 Jan 26 05:28 io8logmt
crw-rw-rw- 1 root wheel 14, 18 Jan 26 16:19 io8logtemp
crw------- 1 root wheel 6, 0 Jan 26 05:28 klog
crw-rw-rw- 1 root wheel 0, 0 Jan 26 05:28 lockstat
crw-rw-rw- 1 root wheel 0, 0 Jan 26 05:28 machtrace
crw-rw-rw- 1 root wheel 3, 2 Jan 26 16:13 null
crw------- 1 root wheel 9, 0 Jan 26 05:28 pf
crw------- 1 root wheel 9, 1 Jan 26 05:28 pfm
crw-rw-rw- 1 root wheel 0, 0 Jan 26 05:28 profile
crw-rw-rw- 1 root tty 15, 1 Jan 26 16:20 ptmx
crw-rw-rw- 1 root wheel 5, 0 Jan 26 05:28 ptyp0
crw-rw-rw- 1 root wheel 5, 1 Jan 26 05:28 ptyp1
crw-rw-rw- 1 root wheel 5, 2 Jan 26 05:28 ptyp2
crw-rw-rw- 1 root wheel 5, 3 Jan 26 05:28 ptyp3
crw-rw-rw- 1 root wheel 5, 4 Jan 26 05:28 ptyp4
crw-rw-rw- 1 root wheel 5, 5 Jan 26 05:28 ptyp5
crw-rw-rw- 1 root wheel 5, 6 Jan 26 05:28 ptyp6
crw-rw-rw- 1 root wheel 5, 7 Jan 26 05:28 ptyp7
crw-rw-rw- 1 root wheel 5, 8 Jan 26 05:28 ptyp8
crw-rw-rw- 1 root wheel 5, 9 Jan 26 05:28 ptyp9
crw-rw-rw- 1 root wheel 5, 10 Jan 26 05:28 ptypa
crw-rw-rw- 1 root wheel 5, 11 Jan 26 05:28 ptypb
crw-rw-rw- 1 root wheel 5, 12 Jan 26 05:28 ptypc
crw-rw-rw- 1 root wheel 5, 13 Jan 26 05:28 ptypd
crw-rw-rw- 1 root wheel 5, 14 Jan 26 05:28 ptype
crw-rw-rw- 1 root wheel 5, 15 Jan 26 05:28 ptypf
crw-rw-rw- 1 root wheel 5, 16 Jan 26 05:28 ptyq0
crw-rw-rw- 1 root wheel 5, 17 Jan 26 05:28 ptyq1
crw-rw-rw- 1 root wheel 5, 18 Jan 26 05:28 ptyq2
crw-rw-rw- 1 root wheel 5, 19 Jan 26 05:28 ptyq3
crw-rw-rw- 1 root wheel 5, 20 Jan 26 05:28 ptyq4
crw-rw-rw- 1 root wheel 5, 21 Jan 26 05:28 ptyq5
crw-rw-rw- 1 root wheel 5, 22 Jan 26 05:28 ptyq6
crw-rw-rw- 1 root wheel 5, 23 Jan 26 05:28 ptyq7
crw-rw-rw- 1 root wheel 5, 24 Jan 26 05:28 ptyq8
crw-rw-rw- 1 root wheel 5, 25 Jan 26 05:28 ptyq9
crw-rw-rw- 1 root wheel 5, 26 Jan 26 05:28 ptyqa
crw-rw-rw- 1 root wheel 5, 27 Jan 26 05:28 ptyqb
crw-rw-rw- 1 root wheel 5, 28 Jan 26 05:28 ptyqc
crw-rw-rw- 1 root wheel 5, 29 Jan 26 05:28 ptyqd
crw-rw-rw- 1 root wheel 5, 30 Jan 26 05:28 ptyqe
crw-rw-rw- 1 root wheel 5, 31 Jan 26 05:28 ptyqf
crw-rw-rw- 1 root wheel 5, 32 Jan 26 05:28 ptyr0
crw-rw-rw- 1 root wheel 5, 33 Jan 26 05:28 ptyr1
crw-rw-rw- 1 root wheel 5, 34 Jan 26 05:28 ptyr2
crw-rw-rw- 1 root wheel 5, 35 Jan 26 05:28 ptyr3
crw-rw-rw- 1 root wheel 5, 36 Jan 26 05:28 ptyr4
crw-rw-rw- 1 root wheel 5, 37 Jan 26 05:28 ptyr5
crw-rw-rw- 1 root wheel 5, 38 Jan 26 05:28 ptyr6
crw-rw-rw- 1 root wheel 5, 39 Jan 26 05:28 ptyr7
crw-rw-rw- 1 root wheel 5, 40 Jan 26 05:28 ptyr8
crw-rw-rw- 1 root wheel 5, 41 Jan 26 05:28 ptyr9
crw-rw-rw- 1 root wheel 5, 42 Jan 26 05:28 ptyra
crw-rw-rw- 1 root wheel 5, 43 Jan 26 05:28 ptyrb
crw-rw-rw- 1 root wheel 5, 44 Jan 26 05:28 ptyrc
crw-rw-rw- 1 root wheel 5, 45 Jan 26 05:28 ptyrd
crw-rw-rw- 1 root wheel 5, 46 Jan 26 05:28 ptyre
crw-rw-rw- 1 root wheel 5, 47 Jan 26 05:28 ptyrf
crw-rw-rw- 1 root wheel 5, 48 Jan 26 05:28 ptys0
crw-rw-rw- 1 root wheel 5, 49 Jan 26 05:28 ptys1
crw-rw-rw- 1 root wheel 5, 50 Jan 26 05:28 ptys2
crw-rw-rw- 1 root wheel 5, 51 Jan 26 05:28 ptys3
crw-rw-rw- 1 root wheel 5, 52 Jan 26 05:28 ptys4
crw-rw-rw- 1 root wheel 5, 53 Jan 26 05:28 ptys5
crw-rw-rw- 1 root wheel 5, 54 Jan 26 05:28 ptys6
crw-rw-rw- 1 root wheel 5, 55 Jan 26 05:28 ptys7
crw-rw-rw- 1 root wheel 5, 56 Jan 26 05:28 ptys8
crw-rw-rw- 1 root wheel 5, 57 Jan 26 05:28 ptys9
crw-rw-rw- 1 root wheel 5, 58 Jan 26 05:28 ptysa
crw-rw-rw- 1 root wheel 5, 59 Jan 26 05:28 ptysb
crw-rw-rw- 1 root wheel 5, 60 Jan 26 05:28 ptysc
crw-rw-rw- 1 root wheel 5, 61 Jan 26 05:28 ptysd
crw-rw-rw- 1 root wheel 5, 62 Jan 26 05:28 ptyse
crw-rw-rw- 1 root wheel 5, 63 Jan 26 05:28 ptysf
crw-rw-rw- 1 root wheel 5, 64 Jan 26 05:28 ptyt0
crw-rw-rw- 1 root wheel 5, 65 Jan 26 05:28 ptyt1
crw-rw-rw- 1 root wheel 5, 66 Jan 26 05:28 ptyt2
crw-rw-rw- 1 root wheel 5, 67 Jan 26 05:28 ptyt3
crw-rw-rw- 1 root wheel 5, 68 Jan 26 05:28 ptyt4
crw-rw-rw- 1 root wheel 5, 69 Jan 26 05:28 ptyt5
crw-rw-rw- 1 root wheel 5, 70 Jan 26 05:28 ptyt6
crw-rw-rw- 1 root wheel 5, 71 Jan 26 05:28 ptyt7
crw-rw-rw- 1 root wheel 5, 72 Jan 26 05:28 ptyt8
crw-rw-rw- 1 root wheel 5, 73 Jan 26 05:28 ptyt9
crw-rw-rw- 1 root wheel 5, 74 Jan 26 05:28 ptyta
crw-rw-rw- 1 root wheel 5, 75 Jan 26 05:28 ptytb
crw-rw-rw- 1 root wheel 5, 76 Jan 26 05:28 ptytc
crw-rw-rw- 1 root wheel 5, 77 Jan 26 05:28 ptytd
crw-rw-rw- 1 root wheel 5, 78 Jan 26 05:28 ptyte
crw-rw-rw- 1 root wheel 5, 79 Jan 26 05:28 ptytf
crw-rw-rw- 1 root wheel 5, 80 Jan 26 05:28 ptyu0
crw-rw-rw- 1 root wheel 5, 81 Jan 26 05:28 ptyu1
crw-rw-rw- 1 root wheel 5, 82 Jan 26 05:28 ptyu2
crw-rw-rw- 1 root wheel 5, 83 Jan 26 05:28 ptyu3
crw-rw-rw- 1 root wheel 5, 84 Jan 26 05:28 ptyu4
crw-rw-rw- 1 root wheel 5, 85 Jan 26 05:28 ptyu5
crw-rw-rw- 1 root wheel 5, 86 Jan 26 05:28 ptyu6
crw-rw-rw- 1 root wheel 5, 87 Jan 26 05:28 ptyu7
crw-rw-rw- 1 root wheel 5, 88 Jan 26 05:28 ptyu8
crw-rw-rw- 1 root wheel 5, 89 Jan 26 05:28 ptyu9
crw-rw-rw- 1 root wheel 5, 90 Jan 26 05:28 ptyua
crw-rw-rw- 1 root wheel 5, 91 Jan 26 05:28 ptyub
crw-rw-rw- 1 root wheel 5, 92 Jan 26 05:28 ptyuc
crw-rw-rw- 1 root wheel 5, 93 Jan 26 05:28 ptyud
crw-rw-rw- 1 root wheel 5, 94 Jan 26 05:28 ptyue
crw-rw-rw- 1 root wheel 5, 95 Jan 26 05:28 ptyuf
crw-rw-rw- 1 root wheel 5, 96 Jan 26 05:28 ptyv0
crw-rw-rw- 1 root wheel 5, 97 Jan 26 05:28 ptyv1
crw-rw-rw- 1 root wheel 5, 98 Jan 26 05:28 ptyv2
crw-rw-rw- 1 root wheel 5, 99 Jan 26 05:28 ptyv3
crw-rw-rw- 1 root wheel 5, 100 Jan 26 05:28 ptyv4
crw-rw-rw- 1 root wheel 5, 101 Jan 26 05:28 ptyv5
crw-rw-rw- 1 root wheel 5, 102 Jan 26 05:28 ptyv6
crw-rw-rw- 1 root wheel 5, 103 Jan 26 05:28 ptyv7
crw-rw-rw- 1 root wheel 5, 104 Jan 26 05:28 ptyv8
crw-rw-rw- 1 root wheel 5, 105 Jan 26 05:28 ptyv9
crw-rw-rw- 1 root wheel 5, 106 Jan 26 05:28 ptyva
crw-rw-rw- 1 root wheel 5, 107 Jan 26 05:28 ptyvb
crw-rw-rw- 1 root wheel 5, 108 Jan 26 05:28 ptyvc
crw-rw-rw- 1 root wheel 5, 109 Jan 26 05:28 ptyvd
crw-rw-rw- 1 root wheel 5, 110 Jan 26 05:28 ptyve
crw-rw-rw- 1 root wheel 5, 111 Jan 26 05:28 ptyvf
crw-rw-rw- 1 root wheel 5, 112 Jan 26 05:28 ptyw0
crw-rw-rw- 1 root wheel 5, 113 Jan 26 05:28 ptyw1
crw-rw-rw- 1 root wheel 5, 114 Jan 26 05:28 ptyw2
crw-rw-rw- 1 root wheel 5, 115 Jan 26 05:28 ptyw3
crw-rw-rw- 1 root wheel 5, 116 Jan 26 05:28 ptyw4
crw-rw-rw- 1 root wheel 5, 117 Jan 26 05:28 ptyw5
crw-rw-rw- 1 root wheel 5, 118 Jan 26 05:28 ptyw6
crw-rw-rw- 1 root wheel 5, 119 Jan 26 05:28 ptyw7
crw-rw-rw- 1 root wheel 5, 120 Jan 26 05:28 ptyw8
crw-rw-rw- 1 root wheel 5, 121 Jan 26 05:28 ptyw9
crw-rw-rw- 1 root wheel 5, 122 Jan 26 05:28 ptywa
crw-rw-rw- 1 root wheel 5, 123 Jan 26 05:28 ptywb
crw-rw-rw- 1 root wheel 5, 124 Jan 26 05:28 ptywc
crw-rw-rw- 1 root wheel 5, 125 Jan 26 05:28 ptywd
crw-rw-rw- 1 root wheel 5, 126 Jan 26 05:28 ptywe
crw-rw-rw- 1 root wheel 5, 127 Jan 26 05:28 ptywf
crw-rw-rw- 1 root wheel 11, 0 Jan 26 16:17 random
crw-r----- 1 root operator 1, 0 Jan 26 05:28 rdisk0
crw-r----- 1 root operator 1, 1 Jan 26 05:28 rdisk0s1
crw-r----- 1 root operator 1, 3 Jan 26 05:28 rdisk0s2
crw-r----- 1 root operator 1, 2 Jan 26 05:28 rdisk0s3
crw-r----- 1 root operator 1, 4 Jan 26 05:28 rdisk1
crw-r----- 1 root operator 1, 5 Jan 26 05:28 rdisk2
crw-r----- 1 root operator 1, 6 Jan 26 05:28 rdisk2s1
crw-r----- 1 root operator 1, 7 Jan 26 05:28 rdisk2s2
lr-xr-xr-x 1 root wheel 0 Jan 26 05:28 stderr -> fd/2
lr-xr-xr-x 1 root wheel 0 Jan 26 05:28 stdin -> fd/0
lr-xr-xr-x 1 root wheel 0 Jan 26 05:28 stdout -> fd/1
crw-rw-rw- 1 root wheel 0, 0 Jan 26 05:28 systrace
crw-rw-rw- 1 root wheel 2, 0 Jan 26 05:28 tty
crw-rw-rw- 1 root wheel 18, 0 Jan 26 05:29 tty.Bluetooth-Incoming-Port
crw-rw-rw- 1 root wheel 18, 42 Jan 26 13:28 tty.SLAB_USBtoUART
crw-rw-rw- 1 root wheel 4, 0 Jan 26 05:28 ttyp0
crw-rw-rw- 1 root wheel 4, 1 Jan 26 05:28 ttyp1
crw-rw-rw- 1 root wheel 4, 2 Jan 26 05:28 ttyp2
crw-rw-rw- 1 root wheel 4, 3 Jan 26 05:28 ttyp3
crw-rw-rw- 1 root wheel 4, 4 Jan 26 05:28 ttyp4
crw-rw-rw- 1 root wheel 4, 5 Jan 26 05:28 ttyp5
crw-rw-rw- 1 root wheel 4, 6 Jan 26 05:28 ttyp6
crw-rw-rw- 1 root wheel 4, 7 Jan 26 05:28 ttyp7
crw-rw-rw- 1 root wheel 4, 8 Jan 26 05:28 ttyp8
crw-rw-rw- 1 root wheel 4, 9 Jan 26 05:28 ttyp9
crw-rw-rw- 1 root wheel 4, 10 Jan 26 05:28 ttypa
crw-rw-rw- 1 root wheel 4, 11 Jan 26 05:28 ttypb
crw-rw-rw- 1 root wheel 4, 12 Jan 26 05:28 ttypc
crw-rw-rw- 1 root wheel 4, 13 Jan 26 05:28 ttypd
crw-rw-rw- 1 root wheel 4, 14 Jan 26 05:28 ttype
crw-rw-rw- 1 root wheel 4, 15 Jan 26 05:28 ttypf
crw-rw-rw- 1 root wheel 4, 16 Jan 26 05:28 ttyq0
crw-rw-rw- 1 root wheel 4, 17 Jan 26 05:28 ttyq1
crw-rw-rw- 1 root wheel 4, 18 Jan 26 05:28 ttyq2
crw-rw-rw- 1 root wheel 4, 19 Jan 26 05:28 ttyq3
crw-rw-rw- 1 root wheel 4, 20 Jan 26 05:28 ttyq4
crw-rw-rw- 1 root wheel 4, 21 Jan 26 05:28 ttyq5
crw-rw-rw- 1 root wheel 4, 22 Jan 26 05:28 ttyq6
crw-rw-rw- 1 root wheel 4, 23 Jan 26 05:28 ttyq7
crw-rw-rw- 1 root wheel 4, 24 Jan 26 05:28 ttyq8
crw-rw-rw- 1 root wheel 4, 25 Jan 26 05:28 ttyq9
crw-rw-rw- 1 root wheel 4, 26 Jan 26 05:28 ttyqa
crw-rw-rw- 1 root wheel 4, 27 Jan 26 05:28 ttyqb
crw-rw-rw- 1 root wheel 4, 28 Jan 26 05:28 ttyqc
crw-rw-rw- 1 root wheel 4, 29 Jan 26 05:28 ttyqd
crw-rw-rw- 1 root wheel 4, 30 Jan 26 05:28 ttyqe
crw-rw-rw- 1 root wheel 4, 31 Jan 26 05:28 ttyqf
crw-rw-rw- 1 root wheel 4, 32 Jan 26 05:28 ttyr0
crw-rw-rw- 1 root wheel 4, 33 Jan 26 05:28 ttyr1
crw-rw-rw- 1 root wheel 4, 34 Jan 26 05:28 ttyr2
crw-rw-rw- 1 root wheel 4, 35 Jan 26 05:28 ttyr3
crw-rw-rw- 1 root wheel 4, 36 Jan 26 05:28 ttyr4
crw-rw-rw- 1 root wheel 4, 37 Jan 26 05:28 ttyr5
crw-rw-rw- 1 root wheel 4, 38 Jan 26 05:28 ttyr6
crw-rw-rw- 1 root wheel 4, 39 Jan 26 05:28 ttyr7
crw-rw-rw- 1 root wheel 4, 40 Jan 26 05:28 ttyr8
crw-rw-rw- 1 root wheel 4, 41 Jan 26 05:28 ttyr9
crw-rw-rw- 1 root wheel 4, 42 Jan 26 05:28 ttyra
crw-rw-rw- 1 root wheel 4, 43 Jan 26 05:28 ttyrb
crw-rw-rw- 1 root wheel 4, 44 Jan 26 05:28 ttyrc
crw-rw-rw- 1 root wheel 4, 45 Jan 26 05:28 ttyrd
crw-rw-rw- 1 root wheel 4, 46 Jan 26 05:28 ttyre
crw-rw-rw- 1 root wheel 4, 47 Jan 26 05:28 ttyrf
crw-rw-rw- 1 root wheel 4, 48 Jan 26 05:28 ttys0
crw--w---- 1 konabob tty 16, 0 Jan 26 16:20 ttys000
crw-rw-rw- 1 root wheel 4, 49 Jan 26 05:28 ttys1
crw-rw-rw- 1 root wheel 4, 50 Jan 26 05:28 ttys2
crw-rw-rw- 1 root wheel 4, 51 Jan 26 05:28 ttys3
crw-rw-rw- 1 root wheel 4, 52 Jan 26 05:28 ttys4
crw-rw-rw- 1 root wheel 4, 53 Jan 26 05:28 ttys5
crw-rw-rw- 1 root wheel 4, 54 Jan 26 05:28 ttys6
crw-rw-rw- 1 root wheel 4, 55 Jan 26 05:28 ttys7
crw-rw-rw- 1 root wheel 4, 56 Jan 26 05:28 ttys8
crw-rw-rw- 1 root wheel 4, 57 Jan 26 05:28 ttys9
crw-rw-rw- 1 root wheel 4, 58 Jan 26 05:28 ttysa
crw-rw-rw- 1 root wheel 4, 59 Jan 26 05:28 ttysb
crw-rw-rw- 1 root wheel 4, 60 Jan 26 05:28 ttysc
crw-rw-rw- 1 root wheel 4, 61 Jan 26 05:28 ttysd
crw-rw-rw- 1 root wheel 4, 62 Jan 26 05:28 ttyse
crw-rw-rw- 1 root wheel 4, 63 Jan 26 05:28 ttysf
crw-rw-rw- 1 root wheel 4, 64 Jan 26 05:28 ttyt0
crw-rw-rw- 1 root wheel 4, 65 Jan 26 05:28 ttyt1
crw-rw-rw- 1 root wheel 4, 66 Jan 26 05:28 ttyt2
crw-rw-rw- 1 root wheel 4, 67 Jan 26 05:28 ttyt3
crw-rw-rw- 1 root wheel 4, 68 Jan 26 05:28 ttyt4
crw-rw-rw- 1 root wheel 4, 69 Jan 26 05:28 ttyt5
crw-rw-rw- 1 root wheel 4, 70 Jan 26 05:28 ttyt6
crw-rw-rw- 1 root wheel 4, 71 Jan 26 05:28 ttyt7
crw-rw-rw- 1 root wheel 4, 72 Jan 26 05:28 ttyt8
crw-rw-rw- 1 root wheel 4, 73 Jan 26 05:28 ttyt9
crw-rw-rw- 1 root wheel 4, 74 Jan 26 05:28 ttyta
crw-rw-rw- 1 root wheel 4, 75 Jan 26 05:28 ttytb
crw-rw-rw- 1 root wheel 4, 76 Jan 26 05:28 ttytc
crw-rw-rw- 1 root wheel 4, 77 Jan 26 05:28 ttytd
crw-rw-rw- 1 root wheel 4, 78 Jan 26 05:28 ttyte
crw-rw-rw- 1 root wheel 4, 79 Jan 26 05:28 ttytf
crw-rw-rw- 1 root wheel 4, 80 Jan 26 05:28 ttyu0
crw-rw-rw- 1 root wheel 4, 81 Jan 26 05:28 ttyu1
crw-rw-rw- 1 root wheel 4, 82 Jan 26 05:28 ttyu2
crw-rw-rw- 1 root wheel 4, 83 Jan 26 05:28 ttyu3
crw-rw-rw- 1 root wheel 4, 84 Jan 26 05:28 ttyu4
crw-rw-rw- 1 root wheel 4, 85 Jan 26 05:28 ttyu5
crw-rw-rw- 1 root wheel 4, 86 Jan 26 05:28 ttyu6
crw-rw-rw- 1 root wheel 4, 87 Jan 26 05:28 ttyu7
crw-rw-rw- 1 root wheel 4, 88 Jan 26 05:28 ttyu8
crw-rw-rw- 1 root wheel 4, 89 Jan 26 05:28 ttyu9
crw-rw-rw- 1 root wheel 4, 90 Jan 26 05:28 ttyua
crw-rw-rw- 1 root wheel 4, 91 Jan 26 05:28 ttyub
crw-rw-rw- 1 root wheel 4, 92 Jan 26 05:28 ttyuc
crw-rw-rw- 1 root wheel 4, 93 Jan 26 05:28 ttyud
crw-rw-rw- 1 root wheel 4, 94 Jan 26 05:28 ttyue
crw-rw-rw- 1 root wheel 4, 95 Jan 26 05:28 ttyuf
crw-rw-rw- 1 root wheel 4, 96 Jan 26 05:28 ttyv0
crw-rw-rw- 1 root wheel 4, 97 Jan 26 05:28 ttyv1
crw-rw-rw- 1 root wheel 4, 98 Jan 26 05:28 ttyv2
crw-rw-rw- 1 root wheel 4, 99 Jan 26 05:28 ttyv3
crw-rw-rw- 1 root wheel 4, 100 Jan 26 05:28 ttyv4
crw-rw-rw- 1 root wheel 4, 101 Jan 26 05:28 ttyv5
crw-rw-rw- 1 root wheel 4, 102 Jan 26 05:28 ttyv6
crw-rw-rw- 1 root wheel 4, 103 Jan 26 05:28 ttyv7
crw-rw-rw- 1 root wheel 4, 104 Jan 26 05:28 ttyv8
crw-rw-rw- 1 root wheel 4, 105 Jan 26 05:28 ttyv9
crw-rw-rw- 1 root wheel 4, 106 Jan 26 05:28 ttyva
crw-rw-rw- 1 root wheel 4, 107 Jan 26 05:28 ttyvb
crw-rw-rw- 1 root wheel 4, 108 Jan 26 05:28 ttyvc
crw-rw-rw- 1 root wheel 4, 109 Jan 26 05:28 ttyvd
crw-rw-rw- 1 root wheel 4, 110 Jan 26 05:28 ttyve
crw-rw-rw- 1 root wheel 4, 111 Jan 26 05:28 ttyvf
crw-rw-rw- 1 root wheel 4, 112 Jan 26 05:28 ttyw0
crw-rw-rw- 1 root wheel 4, 113 Jan 26 05:28 ttyw1
crw-rw-rw- 1 root wheel 4, 114 Jan 26 05:28 ttyw2
crw-rw-rw- 1 root wheel 4, 115 Jan 26 05:28 ttyw3
crw-rw-rw- 1 root wheel 4, 116 Jan 26 05:28 ttyw4
crw-rw-rw- 1 root wheel 4, 117 Jan 26 05:28 ttyw5
crw-rw-rw- 1 root wheel 4, 118 Jan 26 05:28 ttyw6
crw-rw-rw- 1 root wheel 4, 119 Jan 26 05:28 ttyw7
crw-rw-rw- 1 root wheel 4, 120 Jan 26 05:28 ttyw8
crw-rw-rw- 1 root wheel 4, 121 Jan 26 05:28 ttyw9
crw-rw-rw- 1 root wheel 4, 122 Jan 26 05:28 ttywa
crw-rw-rw- 1 root wheel 4, 123 Jan 26 05:28 ttywb
crw-rw-rw- 1 root wheel 4, 124 Jan 26 05:28 ttywc
crw-rw-rw- 1 root wheel 4, 125 Jan 26 05:28 ttywd
crw-rw-rw- 1 root wheel 4, 126 Jan 26 05:28 ttywe
crw-rw-rw- 1 root wheel 4, 127 Jan 26 05:28 ttywf
crw-rw-rw- 1 root wheel 11, 1 Jan 26 05:28 urandom
crw------- 1 root wheel 33, 0 Jan 26 05:29 vboxdrv
crw-rw-rw- 1 root wheel 33, 1 Jan 26 05:29 vboxdrvu
crw------- 1 root wheel 34, 0 Jan 26 05:29 vboxnetctl
crw-rw---- 1 root _windowserver 17, 0 Jan 26 05:28 xcpm
crw-rw-rw- 1 root wheel 3, 3 Jan 26 05:28 zero
Hi Konabob,
I think this is your interface:
/dev/tty.SLAB_USBtoUART
How did you installed the driver for the Silab USB/Serial UART?
I want to try in the same way on my Mac to see what's happen.
