I did remove everything but it still get freezing screen. just a minute ago audio was also running but the rig was set to AM mode and none of the button react. I received a error message that popped up. I made a screen shot. I attach it to my post
I will try again to remove all files again and reinstall the program
regards,
Fokko
- Screenshot_2016-10-21-20-16-44.png (292.19 KiB) Viewed 32655 times
Starting with version 0.9.0-16 you don;t need to reinstall the app. A full reset is now equivalent with a cleanup and reinstall. At first start you are asked which mode to be the default one (WebSDR or Direct CAT).
When do you get that error?
I can not recall exactly after what action I got the message.
And yes I received the selection option regarding CAT or Web SDR. I also see the hardbeat running well. left the small yellow/orange dot en right the green dot. but the app doesn't sync with the RIG. the RIG is set to 0.030 MHz in LSB and I heard noise. But non of the buttons are working however if I touch a button I see the green dot acting.
I tried several times a clean reinstall so I all removed manually ALL related files that where still in the rxtx folder.
Non worked for me however yesterday one time it worked for about 10 minutes and then it got froozen.
73's Fokko
73's Fokko
Additional information: I reinstalled the previous version and this works great again. but with jAReC 0.9
After installing the version 0.8 I installed the version 0.9 just to see what would happen.
I had audio but the RIG was set to LSB. frequency was not changed and non of the buttons act on touching. once again haertbeat yellow and green wher eblinking.
after leaving the program I received beliwe message.
- Screenshot_2016-10-22-14-29-53.png (201.97 KiB) Viewed 32651 times
Hi Fokko,
Do you mean that after installing 0.9.0-16 the version 0.8.x-x does no more work as expected, or the issues are with 0.9.0-16 only?
0.8 works perfect but 0.9 does not work properly
Fokko
Fokko
Hi Fokko,
Please give me more details about the Android version and your device.
My device is still the same a Samsung S5
Android version 5.0.1
Fokko
Fokko
Hello Fokko,
I've tried on my LG G3 with Android 5.0 and I cannot replicate your problem. Please give me the exact steps to get that error.
