New in Pocket RxTx v2.1
Pocket RxTx v2.1 is available in Play Store for more than a week now.
Today I've published a 5 min. video with the new call logging functionality added in this version.
You can find it on my YouTube channel here:
A 5 min. video describing the call logging functionality in Pocket RxTx 2.1 is available now on my YouTube channel here:
https://youtu.be/06fec2FQu9s
Re: New in Pocket RxTx v2.1
Post by do1di »
Thank you for the new APP !!!
where can I see the APP in the future if I have version 2.0, 2.1 etc ... pp ???
And the last Question for Today :)
For the new jAReC Version, which category is meant for that?
Greetings from Germany
cu
Hello Dieter.
When a new version is published, I post an announcement on this forum.
Version 2.2 with a companion app and some new features/bug fixes will be available in a few weeks from now.
I don't understand your last question. You must install always the latest version.subversion from both apps to keep them in sync. If just some bug fixes for jAReC and Pocket RxTx between 2 main releases, then the version number will be 2.1.x
Post by do1di »
Thank you for your Answer !
on my second) question I just wanted to make sure that I am here in the right category.
Allright !
So,
ich habe download the NEW jAReC Version.
it's up to date...
I have not yet tested the callbook function because I mostly work remotely with the software.
So...
So if I click on the new function "Monitor" in remote mode, the color changes to turquoise ...
and see in the new window at Cat Command how he changes momentarily between FE FE 88 E0 15 02 FD and FE FE 88 E0 03 FD (in my case)
You know, I use ICOM
after just (not) 15 seconds, he jumps out of the window and closes it.
with this error
-------------- snip -------------------
PTT command CRC error
expected: 17
received: 81
1 packet(s) lost
1 packet(s) lost
2 packet(s) lost
2 packet(s) lost
2 packet(s) lost
2 packet(s) lost
1 packet(s) lost
2 packet(s) lost
2 packet(s) lost
expected: 81
received: 81FEFE88E003FDFEFE88E01502FDFEFE88E003FD
java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:210)
at java.net.SocketInputStream.read(SocketInputStream.java:141)
at java.net.SocketInputStream.read(SocketInputStream.java:127)
at anywheresoftware.b4a.randomaccessfile.AsyncStreams$AIN.run(AsyncStreams.java:199)
at java.lang.Thread.run(Thread.java:748)
Player2: null
older packet (1) received instead of 179
Exit
------------------- snip ------------------
This error appears both with Windows 7 and / or even with no Linux system.
no matter if I use the Icom ic-7300 or ic-7100. In all cases always the same.
In the field Radio Answer do not happen at all.
but the READ function is still on ice anyway :)
I have more errors or questions but want to finish this part at this point.
so, that was only once
P.S. Remember that I work with Google Translate
Hello Dieter,
do1di wrote: Wed Apr 04, 2018 7:09 pm I have not yet tested the callbook function because I mostly work remotely with the software.
This function is integrated with the radio, so the main purpose is to be used when operating remotely ..:-)
So...
with this error
expected: 17
received: 81
1 packet(s) lost
1 packet(s) lost
2 packet(s) lost
2 packet(s) lost
2 packet(s) lost
2 packet(s) lost
1 packet(s) lost
2 packet(s) lost
2 packet(s) lost
expected: 81
Player2: null
Exit
This looks for me as a seriously communication issue. Do not use audio when in Monitoring mode.
Is not very clear for me from your description what do you intend to achieve.
Can you please make a short video with this and post it here?
Post by do1di »
Thanks Dan,
for your Answer.
So it's not the sound.
have the sound disabled.
Same problem.
But I could narrow things down.
If I set ONLY the frequency on pollig works without crash.
it crashes only when I take the SMETER polling function with it !!!
POLLING=CMD_READ_FREQ works !!!
POLLING=CMD_READ_FREQ,CMD_READ_SMETER works NOT ! ( with crashed )
but the whole READ session does not work anyway anyway.
The correct READ function and syntax is unfortunately not yet guaranteed at ICOM.
So I wait until it happens. No Problem.
Main thing I can use the remote functions before!
Thank you for your help
Many Greetings from Germany
You're right, iCOM use some variable length answers, but this is already supported in the app. Maybe a review of the config is required based on this, but unfortunately I will not be able to do it in the following days as I'm working hard on version 2.2 and a companion app.
ba7ib
Post by ba7ib »
Hi Dan:
I test the new verion jarecmini.jar v2.0 on a raspberrypi 2B, and now it can working with a cheap USB soundcard, but the jarecmini.jar will crash when the client disconnect.
As I'm working hard now on version 3.0 for Pocket RxTx and jAReC, I will check this and fix the issue if something broken.
ba7ib
Post by ba7ib »
Can you tell us what new functions the version 3.0 has? :lol:
