Please include memories in the <station> section.
For each memory you can add an <info> section that is displayed in the lower box (as for the app memories).
Bas
Post by Bas »
I didn't edit my online sdr.xml yet, so whatever you want in it can be done.
Just gave you an idea on how it can be done, I can change/alter it to anything you like, no problem.
I have to collect ON3MS from work, I can insert it in about 30 minutes, just give me what you want it to look like.
Greetz,
Bas.
Ok, so then please let me implement this in the app and be back to you with the final format.
Hope to be able to do it tomorrow.
Bas
Post by Bas »
No problem, let me know and I will add it.
BTW, adding it in the station section breaks with the distribution version, that is not a good idea.
Tested and previous versions will crash on it.
Thanks.
Bas.
Post by do1di »
Hello Bas,
Years ago I asked the general question how to approach the SWebSDR script / tools because pa3fwm@websdr.org does NOT respond to my MANY !!!!! multiple emails.
what am I doing wrong ?
how can I get the script of P.T de Boer?
I can not get on with the OpenwebRx because it is not enough for my purposes.
I hope that I will not embarrass you with my question.
But I would also like to participate with my ICOM 7300 & ICOM 7100.
Thank you for your patience
Many Greetings from Germany
Mary XMAX and HNY
First I want to ask you if you intend to share your transceivers through WebSDR server software. As I'm aware, WebSDR supports only audio and RTL2832 based receivers.
Merry Christmas from Romania.
Post by do1di »
Thank for your Replay !
Naturally
YESSSSSSSSSSS *fg
I have a lot of hardware...
RTL 2832 Dongle...
SDRPlay
Icom IC-7300
Icom IC-7100
etc !!!
I can only say - "Insist!"
I hope Peter is still reading his e-mail.
I'm really sorry that I cannot help you more, as I am not allowed to further distribute WebSDR server software.
Hello everybody.
A new experimental version (3b6) is now available for download.
For all the changes and download links, click https://www.yo3ggx.ro/pocketrxtx/experi ... index.html.
Together with Pocket RxTxE v3b6, jAReC 3b6 and jarecmini 3b6 are available too.
The user guide is now updated for all three applications.
You will be forced to upgrade to 3b6 at next application restart.
Please send me your feedback if you try the new version. This I hope to be the last experimental version before releasing final v3 in Google Play Store.
Post by do1di »
then I want to give a short info...
ADVANCE:
I work with Linux.
all the time I worked with version v3.05b. This ran neatly.
The day before yesterday I discovered the v3.0b6 and immediately downloaded with the appropriate JAVA application.
it does not work for me anymore.
The APP starts, initializes my ICOM IC-7300, turns my display dark, sets power to 1 watt, and MIC auff 0% and then stops. App automatically closed again.
At some point synonymous briefly an info on: Audio INIT Error. APP closed.
In the JAVA application I have only ONE codec. The other is not recognized.
One day later when trying again, the APP informed me that a newer version v3.0b7 will be released
I could NOT defend myself against this download, because with the yes / no query a (no) is NOT accepted and the app closes
That's not nice !!!
You have to change that.
A hint for a new version I like! but you MUST do the download if you want or not
So, download initiated, installed .... same error.
Well, is the v3.0b6 in there again?
As I said Dan, that's how MY Linux behaves at the moment. Version v3.0b5 is running. 6 + 7 not
Windows I can test only next week. Please contact me again and let me know.
Continue to succeed. And thumbs up for your use !!!
may Greetings from Germany
