This is the way I've decided from the beginning to push updates for the experimental version.
As this experimental version is a Pro version, with all the features, the upgrade is enforced and when available in Play Store, will stop working completely.
Is not very clear from your post what is not working. Did you upgraded jAReC or jarecmini to 3b7 too?
For the time when experimental version will be available, you must keep in sync jAReC version with Pocket RxTx version, as some changes may not work with different versions.
I've tested both jAReC 3b7 and jarecmini 3b7 and I have no issues at all.
To download experimental version of jAReC, use this web page:
https://www.yo3ggx.ro/pocketrxtx/experi ... index.html
Post by do1di »
Thank you for your posting.
Okay, understood that makes sense in the test phase
Unfortunately, under the link I find only the JAVA version v3.0b6 *fg :))
But I will test it as promised.
Thank you and best regards
73 de DO1Di / Dieter
3b6 is good with PocketRxTx 3b7 and 3b8 (to be posted later today).
As a general rule, use the latest available Pocket RxTx and jAReC versions.
Post by do1di »
Okay, all right. I thought the link would be wrong because of the version number
Will test it again next week on my system.
Thanks and nice weekend
Version 3b8 is now posted, that fix a bug.
jAReC and jarecmini versions are now in sync with Pockeyt RxTx version, to prevent confusion.
Post by do1di »
no one else here except me? * fg
then I want to give a short status...
So then first: all-clear !!!
Android APK and JAVA application v3.0b8 installed
IT WORK's !!!
have while turning on and off a message:
--------- snip -----------
c:\afu\yo3ggx\v3.0b8>java -jar rAReC_v3.0b8.jar
reconnect
reconnect
java.lang.ClassCastException: javafx.scene.control.MenuItem cannot bet cast to vafax.scene.control.CheckMenuItem
reconnect
Disconnet5
Player2: null
disconnect terminated
Player2: null
Disconnect4
------------- snip -------------
as I said, works anyway !!!
Great !
then I noticed the following
the CFG EXP & CFG IMP works
the directory CONFIGS is created and also the files are copied into it
also the ic7300.mem
the entries from the M1 - M8 are also available (in the .MEM file)
but are NOT in the APP AFTER restarting the APP
also the entries like LSB etc. PWR are ALWAYS gone
is it possibly only with me?
but that's enough for today :)
Thank you DAN an many Greetings from Germany
I will check the reported issue with jarecmini and the memories and be back to you.
Version 3.0 final was published in Google Play Store., so this thread will be closed.
Please continue the discussion in the thread dedicated for the new version:
viewtopic.php?f=15&t=620
