Will be fixed in v4b10.SY1DAL wrote: Thu Oct 14, 2021 2:10 pm I coundn't agree more. I believe that optional is the best solution. But noticed that when enabled, indeed the boxes open behind or to the left and some to the right of the main window (the main window keeps the focus) in some cases, and regarding the meter button... if you press it twice or 3 times... the box will open 3 times ... as many times you click on it ... it will open these many times you click. Of course with happens with "always on top" toggle. When its off... everything works fine.
Will be in v4b10 a separate button too...Keyboard shortcuts are always nice to have in any application. But i would definetely suggest a PTT lock function in the main PTT button (i have attached a picture / no my best design tho hehehe).
Then you can eventually try SWR function to get the graph for the current band. In this way you can check how reliable is SWR reading from the radio.I am also aware and saw the tuner functionatilies... I have selected "transceiver" option for me as i use the internal tuner of the radio (ft-450) but since my antenna is with swr 1.1 on 4 bands... i never use nowadays.
Yes, the idea is to be able to operate the radio remotely over the network from another jAReC in client mode.Where will it come handy to use client mode ? I must have two PC's for that ? its like a remote connection from a client PC to a host PC right ? I can test it i assume..![]()
Did you tried to use a headset with jAReC?
Nice!I have to video links of video screenshots regarding the power meter test and also the test of SWR functionality.
1. Power Meter test (to catch the 0) https://www.iplayradio.net/cdn/files/pu ... r-zero.avi
2. SWR test https://www.iplayradio.net/cdn/files/pu ... -again.avi
