Now I'm totally confused.SY1DAL wrote: Thu Oct 14, 2021 3:54 pm I do have an audio headset to connect without disconnecting anything else... but i have to be in the radio shack. Where i live is 50 km range from the radio shack.
Why you need to be close to the radio? You connect the headset to the PC where you are now, not to the one where the radio is.
I've seen that you are using VNC to connect to the remote PC. With jAReC you don't need it. Run jAReC as server in remote location (where the radio is) and jAReC client on the local PC, where you connect the headset too.
Connect to the remote PC through jAReC, not through VNC.
