jAReC v4.2 was released
Here we discuss about both jAReC and jarecmini
What's new:
  • Windows x64 package now contains an updater script that can be used to update to the latest available version in just a few seconds, without loosing any previous application configuration.
  • two install/update scripts are now available for linux (Debian flafour). One use java11, the other java17. Use the one that works best for you.
  • new audio library (both UDP and TCP audio).
  • audio over TCP supported in v3 compatibility mode too (to be used with Pocket RxTx v3.4 and up).
  • Network audio mode (UDP or TCP) is shown on the configuration page in both Server modes.
  • Audio loopback is shown on the configuration mode in Both Server and in Client modes.
  • central repository copy (from the compilation date) stored in the application (to be used if no Internet access or when central repository is not available).
Solved bugs:
  • when disconnected from the client, it takes some timwe to re-enter listening mode.
  • audio volume level meter not working in SRV v3 mode.
  • app crash when minimized, if installed using the script.
Available downloads:
Windows x64 packaged version(64bit) - https://www.yo3ggx.ro/jAReC/v4/jAReC_v4.2_win_x64.zip.
Mac x86_64 signed packaged version(64bit) - https://www.yo3ggx.ro/jAReC/v4/jAReC_v4 ... x86_64.zip.
Installer/updater for Linux (java 11) - https://www.yo3ggx.ro/jAReC/v4/jarec_installer11.sh. Use for all 32/64bit distros based on Debian (including Raspberry Pi and Chrome OS).
Installer/updater for Linux (java 17) - https://www.yo3ggx.ro/jAReC/v4/jarec_installer17.sh. Use for all 32/64bit distros based on Debian (including Raspberry Pi and Chrome OS).
jar file (64bit)- https://www.yo3ggx.ro/jAReC/v4/jAReC_v4.2_x64.jar. Use for all other platforms not listed above.
jar file (32bit)- https://www.yo3ggx.ro/jAReC/v4/jAReC_v4.2_x86.jar. Use only for 32 bit Windows with Oracle Java 1.8-xxx. Some features may not be available.
Use this thread only to discuss version 4.2.
ba7ib
Re: jAReC v4.2 was released
Post by ba7ib »
Can jAReC v4 running without DISPLAY on a RaspberryPI ?
Hello.
jAReC v4 can work without a physical display, but does require an X server to run, as is based on javaFX. You can set it up remotely through VNC. There is no console version for v4 and I do not have plans to build one.
R1BLH
Post by R1BLH »
Thanks for the release!
Just made some QSO through the client-server. The radio station is in St. Petersburg, I am in Ribnita, Moldova.
