Jarec with Yaesu FT-991
I just installed jarec version 4 with my yaesu FT991 computer, but I can't get the cat to activate with the version I downloaded. I only hear sound, ports and speed is correct because I use it with other remote programs, I don't know where it can be the problem
Re: Jarec with Yaesu FT-991
I also have tried to get the cat to work on a 991 and failed. Windows 11, Yaesu Drivers, JarEc 4.2, pRxTx 3.3.3.
Checked baud rates, tried slower, tried faster. 8N2 on serial port.
The Radio just won't update. An odd observation though, if I change the Frequency nothing happens.... But hot unplugging the USB sometimes updates the radio. As if the termination character for the string is not present. This USB cable works fine with other software, not transmitting so likely not RFI.
Definitely think it is JarEc to 991. Just uncertain the next debug step.
Mike
Mike
Self Fixed: CAT RTS DISABLE
Thank you, I've been pulling my hair out since I did the FT-991A firmware upgrade!
