Hi Fredo,
fy4pr wrote:
...But the Power is not correct, it's always 5W shown on Pocket TX, indeed it's 100W really on the transceiver.
I have no FT-857 to check something so maybe you can help.
Please install and run HRD ip (updated last Saturday) and play with the commands related to Power:
I need to know the specific values for 5, 10, 25 and 100W (both set and get).
The Pocket TX frequency can vary himself, and go to 0.03200... after waiting a while it go back to the real FT857 frequency... But it's most usually on 0.03200 than on the good QRG.
I'm aware about this issue but I still think is a problem in IP Server implementation in HRD. 0.032 mean that HRD returned (for some strange reasons) value 0 for frequency when asked.
Maybe is not able to handle very fast querries. As there is no documentation, I can just suppose.
The Signal meter still on S9+60 when on 0.03200, and show the real S when on the real QRG.
When on 0.032 all the values can be messed up.
I can callback a memory channel, but only one, if i callback an other memory channel, the pocket TX soft bug and no more dialog between HRD and the phone (small yellow light stop blinking), i have to disconnect and connect again.
I will try to find a way to compensate this "bug".
The PTT button work bad, if i stay pushed, the transceiver really TX after 3 or 4 seconds and go back in RX after 2 secs...
The PTT button just send the command to the transceiver immediately. Only when the feedback from transceiver was received that the command executed successfully, then the PTT button goes red.
For me even over 3G the feedback is fast enough for normal operation.
On the top left corner of the frequency counter, the name can change.
Sometimes it's "RADIO?", or "192" or "FT857" or "Ham Radio Deluxe" ... don't know what it mean.
That name is set only when powering on the app  by pressing the round button. Do you mean that the name changes during operation?
If yes, then most probable is a problem with the communication.
But however, it's not usable like that, i've got a lot of bug, lot of connection freeze, and too much latence.
1 time i pushed the PTT button on my smartphone, the FT-857 put in transmit mode, and it freeze. I pull off my finger of the PTT button but the FT857 stayed on TX! I had to shutoff the transceiver by the ON/OFF button to go back in RX. Very dangerous if happen when you're not at your shack!
Do not forget that IP Server nor HRD Remote Server does not provide any kind of checksums for the communication, so there is no way to know when an error occurs.
This may happen (theoretically) even if you use HRD remotely and not my app. Maybe I'm pushing to far the capabilities provided by the IP Server...
You have all these issues when using it over the WiFi?
I will implement in a future version a watchdog for PTT. How do you send PTT from HRD to transceiver? Over CAT or using RTS?
Hope it help!
Very useful feedback. Let's tryu to solve your issues one by one.
73'
Fredo
73 dan YO3GGC
