This is my config file, can not find it.
; This is the configuration file for an Yaesu FT-817 transceiver
; Use "," for parameters separation
Brand=Yaesu
Model=FT817
sigRadios=$1gR@d10s
; Frequency coverage
FRANGE=100000-56000000,76000000-154000000,420000000-470000000
; List of available Bands
BANDS=160m,80m,40m,30m,20m,17m,15m,12m,11m,10m,6m,4m,2m,70cm
; first wheel - list of available modes in the MODE wheel (starts with wheel name)
LST1NAME=MODE
LST1ITEMS=LSB,USB,CW,CWR,AM,FM,DIG
LST1CMDS=CMD_SET_MODE_LSB,CMD_SET_MODE_USB,CMD_SET_MODE_CW,CMD_SET_MODE_CWR,CMD_SET_MODE_AM,CMD_SET_MODE_FM,CMD_SET_MODE_DIG
; second wheel - list of available powers in the PWR wheel (starts with wheel name)
LST2NAME=PWR
LST2ITEMS=0.5W,1.0W,2.5W,5.0W
LST2CMDS=CMD_SET_PWR_0.5W,CMD_SET_PWR_1.0W,CMD_SET_PWR_2.5W,CMD_SET_PWR_5.0W
; Option Button config (name,odd_press_cmd,even_press_cmd,odd_press_label,even_press_label
BTN_OPT1_NOFN=VFO,CMD_SET_VFO_A=VFO-A,CMD_SET_VFO_B=VFO-B
BTN_OPT2_NOFN=NB,CMD_SET_NB_OFF=OFF,CMD_SET_NB_ON=ON
BTN_OPT3_NOFN=AGC,CMD_SET_AGC_OFF=OFF,CMD_SET_AGC_SLOW=SLOW,CMD_SET_AGC_FAST=FAST,CMD_SET_AGC_AUTO=AUTO
BTN_OPT4_NOFN=
BTN_OPT5_NOFN=ATT,CMD_SET_ATT_OFF=OFF,CMD_SET_ATT_ON=ON
BTN_OPT1_FN=
BTN_OPT2_FN=
BTN_OPT3_FN=
BTN_OPT4_FN=
BTN_OPT5_FN=
; List of available commands for the current transceiver, all items from the list are one byte equivalent, BCD (2 digits as chars) or strings
; <Pxxxx> as 'byte' to separate two successive commands by a xxxx ms delay
; <Dxx> - frequency numeric digits - BCD packed (from 9, thousands MHz to 0 - Hz)
; <Cx> - frequency char digit (from 9, thousands MHz to 0 - Hz)
; <Sxxxxxxx> - string xxxxxx)
; <#param;value> - set app internal parameter to value
; xx,xx,... - bytes represented as hex string values
; <MxXXXXXXXX=val> - send an EEPROM memory location; x=1:locatia adresata, x=2:urmatoarea locatie, XXXXXXXX:binary mask, val:binary value to include in the mask zone
CMD_SET_FREQ=<D87>,<D65>,<D43>,<D21>,01
CMD_SET_PTT_ON=00,00,00,00,08
CMD_SET_PTT_OFF=00,00,00,00,88
CMD_SET_MODE_LSB=00,00,00,00,07
CMD_SET_MODE_USB=01,00,00,00,07
CMD_SET_MODE_CW=02,00,00,00,07
CMD_SET_MODE_CWR=03,00,00,00,07
CMD_SET_MODE_AM=04,00,00,00,07
CMD_SET_MODE_FM=08,00,00,00,07
CMD_SET_MODE_DIG=0A,00,00,00,07
CMD_SET_MODE_PKT=0C,00,00,00,07
CMD_SET_VFO_A=00,55,10100000,00,BC
CMD_SET_VFO_B=00,55,10100001,00,BC
; EEPROM 0057:
; 1,0[00 = Auto, 01 = Fast, 10 = Slow, 11 = Off AGC Mode]
; 2[0 = Off, 1 = On (Display format)]
; 3[0]
; 4[0 = Off, 1 = On (Passband Tuning)]
; 5[0 = Off, 1 = On (Noise Blanker)]
; 6[0 = Off, 1 = On (Dial Lock)]
; 7[0 = Off, 1 = On (Fast tuning)]
; EEPROM 0058:
; 1,0[00 = PWR, 01 = ALC, 10 = SWR, 11 = MOD (Pwr Meter Mode)]
; 2[0 = Normal, 1 = Reverse (CW Paddle Normal/Reverse (#19))]
; 3[0]
; 4[0 = Off, 1 = On (CW Keyer)]
; 5[0 = Off, 1 = On (Semi Break-In)]
; 6[0 = Off, 1 = On (Voltmeter Display)]
; 7[0 = Off, 1 = On (VOX On/Off)]
; hex values to initialize EEPROM locations 57 and 57 (in hex)
EEPROM0057=00
EEPROM0058=40
;CMD_SET_AGC_OFF=00,57,<M111111100=0>,<M211111111=00>,BC
;CMD_SET_AGC_SLOW=00,57,<M111111100=2>,<M211111111=00>,BC
;CMD_SET_AGC_FAST=00,57,<M111111100=1>,<M211111111=00>,BC
;CMD_SET_AGC_AUTO=00,57,<M111111100=3>,<M211111111=00>,BC
CMD_SET_SPLIT_ON=00,00,00,00,02
CMD_SET_SPLIT_OFF=00,00,00,00,82
CMD_SET_LOCK_ON=00,00,00,00,00
CMD_SET_LOCK_OFF=00,00,00,00,80
CMD_SET_CLARIFIER_ON=00,00,00,00,05
CMD_SET_CLARIFIER_OFF=00,00,00,00,85
CMD_SET_DCS_ON=0A,00,00,00,0A
CMD_SET_CTCSS_ON=2A,00,00,00,0A
CMD_SET_ENCODER_ON=4A,00,00,00,0A
CMD_SET_ENCODER_OFF=8A,00,00,00,0A
CMD_SET_POWER_ON=00,00,00,00,80,<P1000>,00,00,00,00,0F,
CMD_SET_POWER_OFF=00,00,00,00,80,<P1000>,00,00,00,00,8F,<P1000>
; EEPROM WRITE
; MSB LSB Data4Address Data4Address+1 BC
CMD_SET_PWR_0.5W=00,79,03,00000000,BC
CMD_SET_PWR_1.0W=00,79,02,00000000,BC
CMD_SET_PWR_2.5W=00,79,01,00000000,BC
CMD_SET_PWR_5.0W=00,79,00,00000000,BC
; read commands format
; command,separator(<R>)nr.of.expected.bytes/binary mask if one byte answer or bytes order (<Bx> if multiple bytes, where 0 is used for dummy byte (if any)
;CMD_READ_FREQ=00,00,00,00,03,<R>,<D87>,<D65>,<D43>,<D21>,<00>
;CMD_READ_MODE=00,00,00,00,03,<R>,<00>,<00>,<00>,<00>,<00=LSB;01=USB;02=CW;03=CWR;04=AM;06=WFM;08=FM;0A=DIG;0C=PKT>
;CMD_READ_SMETER=00,00,00,00,E7/<00001111>
;CMD_READ_SWR=00,00,00,00,F7/<00001111>
;CMD_READ_ALC=00,00,00,00,F7/<00001111>
;CMD_READ_MOD=00,00,00,00,F7/<00001111>
; list of commands to be sent at startup (usually read different parameters in order to be able to work after that without feedback, for max. responsiveness
STARTUP=CMD_SET_LOCK_OFF
Newest update No HRD?
Re: Newest update No HRD?
This is the section:
CMD_SET_PWR_0.5W=00,79,03,00111111,BC
CMD_SET_PWR_1.0W=00,79,02,00111111,BC
CMD_SET_PWR_2.5W=00,79,01,00111111,BC
CMD_SET_PWR_5.0W=00,79,00,00111111,BC
And rear antenna will be used for all the bands.
Just change it to:iw1ghg wrote:This is my config file, can not find it.
I had not read well in the post.
Thank you, everything ok, I solved it.
You can play with the config file and add any available command you need to one of the 10 option buttons.
Good luck.
Good luck.
