Experimental Pocket RxTx version (0.9) & jAReC 0.9
Re: Experimental Pocket RxTx version (0.9) & jAReC 0.9
Post by MysticFire »
On a Honor 7 with Lollipop 5.0.2 WebSDR works. May be a KitKat Problem
Gesendet von meinem D6603 mit Tapatalk
I confirm that PTT does not work in direct CAT over Bluetooth or USB mode. Is an unexpected side effect of the PTT mode intruduced for direct CAT over the network. I will correct this in the next release which I expect to post here later this week.
Can you confirm that the "fixed S4" issue is still present on your KitKat device?
Please download the "work in progress" version 0.9.0-2 from here:
https://www.yo3ggx.ro/pocketrxtx/pocket ... .9.0-2.apk
and check if PTT is working now.
There are some other changes too, but I will describe them in the updated version of the user guide and then post the new prerelease here.
I go to test it
Seems the cat control works now on KitKat and Lollipop. WEBSDR only in Lollipop for me. Pls the old Ptt with Sticky on short press without the swipe for me
MysticFire wrote:Seems the cat control works now on KitKat and Lollipop. WEBSDR only in Lollipop for me.
What do you mean by don't work in KitLat?
The old sticky mode was very confusing for many users, so I was forced to change it in the new release.
Kitkat means Android 4.4.4
MysticFire wrote:Kitkat means Android 4.4.4
Of course I know that KitKat is android 4.4.x, but what is not working in KitKat?
Can you provide more details?
On Kitkat Websdr still gives no Audio and S Meter Stuck on a certain Level no Matter if 8000 or else is choosen
I am not able to replicate this on my LG L70 with KitKat....
Maybe someone else reading this thread can help with more info.
