Kenwood TS-480 error ?
SQ7OVT
Re: Kenwood TS-480 error ?
Post by SQ7OVT »
I have set the same port (9876) in both programs on the PC and the app, the app shows the CAT, PTT, and audio supports one and the same port, ie. me 9876.
Where to set the radio feedback ?
73's de SQ7OVT Slawek.
In jAReC mode, you can configure only the CAT port, audio uses the next port. Is a mistake in the interface, I will correct this in the next version.
In your case, audio will use port 9877. PTT command is sent over the same port as CAT in jAReC mode.
You can activate/deactivate feedback from Pocket RxTx. Is the round gray button in the right part of the tuning knob.
