jAReC5 beta 1
vk3tr
Re: jAReC5 beta 1
Post by vk3tr »
Is the v5 beta still downloadable? I'm getting an error when I run the installer script in Linux.
For example:
sparc@grendel:~$ ./jarec_installer17.sh -i
jAReC v5 installer/updater version 1.2 for Debian based Linux distribution (including arm32 and arm64)
OS achitecture: amd64
jAReC v4 install
Check if Java 17 is installed...
Java Version: 17.0.8+7-1~22.04  is already installed
Check if JavaFX 11 is installed...
JavaFX Version: 11.0.11+0-1  is already installed
Check if wget is installed...
wget Version: 1.21.2-2ubuntu1 is already installed
Downloading latest jAReC v5.x version ...
Cannot download the latest jAReC version from the central repository
Please check again later
do1di
Re: jAReC5 beta 1
Post by do1di »
Thank you for your new V5 Beta Version !!!
I like It !!!
Here is some of my feedback
1,)
In your FIRST entry of this Tread you are wrote:
Online User Guide (Multilingual) <a href="/jAReC/v5/doc/index.html">here</a></b>
Offline User Guide (PDF-EN) <a href="/jAReC/v5/doc/jAReC_v5.0_beta1_en.pdf">here</a></b>
did you make a small mistake?
the link is not selectable
I managed to download the user guide myself
but you should fix it for subsequent users :)
2.)
unfortunately I have to agree with the VK3TR
the same problem occurs with me too.
even in the V4 version.
install.sh does not work correctly and no start.sh is created afterwards.
I downloaded the 64-bit Windows version and it runs under WIN11 as far as the RUN.BAT !!!
3.)
SELECT BAND...
found a small error
Under Select Bans 2 Buttons are not corectly work
CB + 2 Mtr. are switchin to 24.890.000 ;Hz :)
4.)
WATERFALL...
Waterfall under YAESU FT-991a not supported for this Radio.
Is this an YAESU Problem, or only for FT-991A ??
I'm new Profile started with ICOM IC-7300 - that ist availble,
but still not satisfied.
but first I'll see if it's not my fault!!!
So that was feedback from me for a long time :)
Thank you for your great work and I'm looking forward to the Andriod APP pRxTx v5 :)
pRxTxE(xperimantel) are not longer works by me
did you disable it?
and I first uninstalled :)
greetings from Germany
and good luck with your project.
Many Thanks
73 de DO1DI / Dieter
P.S.
I hope google translator did a good job :)
Re: jAReC5 beta 1
Hello Dieter,
First I'm really sorry for the very late reply, I had issues with the forum notifications, so I was not aware about your post and I don't have enough time to poll the forum.
1. Checked my web site now and I don't see any issue with the documentation links (both online and PDF). Maybe I fixed this in between,
2. All download link fixed. Which "install.sh " does not work as expected?
What do you mean by "I downloaded the 64-bit Windows version and it runs under WIN11 as far as the RUN.BAT !!!"?
3. noted and will be fixed
4. As I'm aware, FT991 does not provide documented waterfall data over CAT, like Icom.
Please detail what do you mean by "I'm new Profile started with ICOM IC-7300 - that ist availble, but still not satisfied."
Currently jAReC5 development is paused, to concentrate on a new version of Pocket RxTx (3.4).
After that I will switch back to Pocket RxTx5, the Android counterpart of jAReC5.
In v3.4 I'm implementing some features initially planned for Pocket RxTX5.
If you want to play with Pocket RxTx v3.4 beta, I can send you details over email, as the links are not yet public.
vk2kes
Re: jAReC5 beta 1
Post by vk2kes »
You wrote "If you want to play with Pocket RxTx v3.4 beta, I can send you details over email"
Please PM me details over email
Kesh VK2KES
do1di
Re: jAReC5 beta 1
Post by do1di »
Like I said, no problem at all.
I'm really looking forward to reading you again.
​And as I said - everything is in peace.
As always, you're doing a great job.
Then it can take longer :)
And I'm excited and very interested in the new changes and versions!
Good Luck and Greetings from Germany
Re: jAReC5 beta 1
Hello Dieter.
I'm doing my best. Unfortunately 24h are not enough for a day to do my job and work for the hobby ....
