sorry for delay, crazy days in work past 2 weeks, many days outside my city + 2 little childrens = no time at home for hobby.
4m - My radio ending on 56.000 MHz with all mode. Then starts on 76.00 - 108 MHz, but only WFM. No 4m hamband possibility. HW limitations of FT-857.
Im deleted old confing and load MysticFire.
FMN is now working. Now is PKT mode not working, also when manualy switched via display on radio stays on PocketRXTX last modulation.
PWR set still not working. In PocketRXTX is 0,5 ; 1,0 ; 2,5 ; 5,0 ; 20 ; 45 ; 75 ; 100W. But PWR from FT857 on 160m to 6m is 5 to 100W. On 2m is 5 to 50W and on 70cm is 2W to 20W. This is possible settings via display. Maybe values outside are problem.
SWR meter is not working, with unplugged antenna with 5W (yes, im know, dirty) on VHF / HF and with HISWR (and full bargraph in SWR metering mode) on display PocketRXTX is SWR 1
Switching betwen rx (s-meter) and TX (SWR meter) now works, tried many times.
Big problem for remote operation is radio hang on TX when BT / network is disconnected during transmission, needs to setup TOT in radio to safe value (for me 2 min), menu 084 in FT-857D.
Frequency readings when is changed on radio now works...
VFO, CTC, DCS, VFO under FN not works. SPLIT, LOCK not present.
Workset for Anton preset is not possible to start, same picture as MysticFire » Mon Sep 07, 2015 5:09 pm
Im using FT-857 as backpack radio for sota and florafauna activations, in this case is direct control faster and safer as via PocketRXTX. Other time lies in backpack at home without using. My post are only for information, you don't must work on this problem for me
For me is play, not needs.
For intermittent remote using via PC and smartphone im using IC7000 with BKT solutions directly written for this radio together with my wife for remote On and Off of IC7000 by comand via phone
Sry for poor english.
Chers, Anton
