jAReC Linux
Re: jAReC Linux
I will take a look at this issue. I think is related to the latency, so for a short period the Rx signal is returned to Tx (through the mike) until the switch is complete.
If this is the case, I will fix it in the next release. Thank you for your bug report.
Re: jAReC Linux
I said earlier that jarec stays on in raspberry, but this was not the case. When I turn off pocketrxtx, jarec turns off almost immediately.
Re: jAReC Linux
By turn off you mean going offline (not listening) or is closing?
Do you get any error messages in the console?
Re: jAReC Linux
Jarec shuts down completely, disappears from the desktop. Startup must be started from the beginning. There is no error message. A friend told him the same would happen. Likewise, autostart does not work.
Re: jAReC Linux
When you run jAReC from the console, you must get an error message when closed unexpectedly.
If you run the old packaged version, use run_debug to launch the application.
Please send me that error message.
Re: jAReC Linux
yo3ggx wrote: Fri Mar 10, 2023 11:59 am I will take a look at this issue. I think is related to the latency, so for a short period the Rx signal is returned to Tx (through the mike) until the switch is complete.
is there still a beta version available where this latency problem has been fixed? Now I don't feel like using the program because I keep getting comments about it. I gave up using krisp because its price went up by 50%.
Re: jAReC Linux
No other beta version released yet, as currently I'm working on jAReC v4.3, with support for IQ based SDR (Malahit DSPx, Softrock, etc), RTLSDR dob with waterfall, in-app demodulation and an audio DSP with different user configurable filters through GUI. The features will be available later in Pocket RxTx v4 (some of them maybe even in v3.x).
