Re: ICOM radios config files
Posted: Mon Mar 05, 2018 4:45 pm
You need to define read commands for each, including calibration data, and then to add the commands to the POLLING line.LakisFM1 wrote: Sun Mar 04, 2018 7:49 pm I still haven't understand how to see PWR SWR etc... are they displayed when replies arrived , or should i tick the meter-bar to select the corresponding type?
Pocket RxTx will read only S-meter when in Rx and only the selected meter (through a long press) in Tx (SWR, PWR,ALC or MOD), even if all are added to the POLLING line.
This does not help as some signals must be applied to test meters. The Monitoring function in jAReC 2 is the best way to test READ commands and validate your config (including calibration data).I even can provide you direct access to my tranceiver , if that helps.
Unfortunately I'm very busy at the office this week with no time to work on the configs.
