Yaesu radios config files
Re: AW: Yaesu radios config files
Post by MysticFire »
Good Advice. Always good to have a Backup first
http://www.mumble-funk.de - Freier Funk für PC/Android/Iphone
MysticFire wrote:Good Advice. Always good to have a Backup first
In Pocket RxTx there is a protection implemented. Even if you define in the config file an "Reset FT-817 to factory defaults and blow away all "soft" calibration settings" command (xx xx xx xx BE) this is filtered by the application and not sent to the radio.
Unfortunately this does not prevent you to send individual write commands for a specific location, so an EEPROM backup before playing with Pocket RxTx is mandatory. This is specified in the application user guide too.
Re: Yaesu radios config files
It seems that with FT857D (in my case), current command to read PTT status:
CMD_READ_PTT=04,00,00,00,00,00,F7,<R>,01,<0xxxxxxx=ON;1xxxxxxx=OFF>
is not the right one. As stated here:
http://www.ka7oei.com/ft817_meow.html
"Command F7 - Read Transmitter Status: This command returns one byte containing the current transmitter status. This data is invalid when the radio is in receive mode. This data is as follows:
Bit 7 indicates the current PTT status: 0 = Unkeyed, 1 = Keyed"
This means that you can read PTT status as much as the radio is in Tx, but as soon as back in Rx mode, you cannot detect this through this read command.
We need to find something else.
I made VFO work on fn too, and SPLIT works now too.
Brand=Yaesu
Model=FT857
sigRadios=$1gR@d10s
; Frequency coverage
FRANGE=100000-56000000,76000000-108000000,118000000-164000000,420000000-470000000
; List of available Bands
BANDS=160m,80m,40m,30m,20m,17m,15m,12m,11m,10m,6m,4m,2m,70cm
; first wheel - list of available modes in the MODE wheel (starts with wheel name)
LST1NAME=MODE
LST1ITEMS=LSB,USB,CW,CWR,AM,FM,FM-N,DIG,PKT
LST1CMDS=CMD_SET_MODE_LSB,CMD_SET_MODE_USB,CMD_SET_MODE_CW,CMD_SET_MODE_CWR,CMD_SET_MODE_AM,CMD_SET_MODE_FM,CMD_SET_MODE_FM-N,CMD_SET_MODE_DIG,CMD_SET_MODE_PKT
; second wheel - list of available powers in the PWR wheel (starts with wheel name)
LST2NAME=PWR
LST2ITEMS=0.5W,1.0W,2.5W,5.0W,20.0W,45.0W,75.0W,100.0W
LST2CMDS=CMD_SET_PWR_0.5W,CMD_SET_PWR_1.0W,CMD_SET_PWR_2.5W,CMD_SET_PWR_5.0W,CMD_SET_PWR_20.0W,CMD_SET_PWR_45.0W,CMD_SET_PWR_75.0W,CMD_SET_PWR_100.0W
; Option Button config (name,odd_press_cmd,even_press_cmd,odd_press_label,even_press_label
BTN_OPT1_NOFN=VFO,CMD_SET_VFO_TOGGLE=AB
BTN_OPT2_NOFN=
BTN_OPT3_NOFN= SQMOD,CMD_SET_CTCSS_OFF=OFF,CMD_SET_DCS_ON=DCSON,CMD_SET_DCS_TXON=DCSTX,CMD_SET_CTCSS_ON=CTCON,CMD_SET_CTCSS_TXON=CTCTX
BTN_OPT4_NOFN=CTCSS,CMD_SET_CTCSS_67=67,CMD_SET_CTCSS_69.3=69.3,CMD_SET_CTCSS_71.9=71.9,CMD_SET_CTCSS_74.4=74.4,CMD_SET_CTCSS_77=77,CMD_SET_CTCSS_79.7=79.7,CMD_SET_CTCSS_82.5=82.5,CMD_SET_CTCSS_85.4=85.4,CMD_SET_CTCSS_88.5=88.5,CMD_SET_CTCSS_91.5=91.5,CMD_SET_CTCSS_94.8=94.8,CMD_SET_CTCSS_97.4=97.4,CMD_SET_CTCSS_100=100,CMD_SET_CTCSS_103.5=103.5,CMD_SET_CTCSS_107.2=107.2,CMD_SET_CTCSS_110.9=110.9,CMD_SET_CTCSS_114.8=114.8,CMD_SET_CTCSS_118.8=118.8,CMD_SET_CTCSS_123=123,CMD_SET_CTCSS_127.3=127.3,CMD_SET_CTCSS_131.8=131.8,CMD_SET_CTCSS_136.5=136.5,CMD_SET_CTCSS_141.3=141.3,CMD_SET_CTCSS_146.2=146.2,CMD_SET_CTCSS_151.4=151.4,CMD_SET_CTCSS_156.7=156.7,CMD_SET_CTCSS_162.2=162.2,CMD_SET_CTCSS_167.9=167.9,CMD_SET_CTCSS_173.8=173.8,CMD_SET_CTCSS_179.9=179.9,CMD_SET_CTCSS_186.2=186.2,CMD_SET_CTCSS_192.8=192.8,CMD_SET_CTCSS_203.5=203.5,CMD_SET_CTCSS_206.5=206.5,CMD_SET_CTCSS_210.7=210.7,CMD_SET_CTCSS_218.1=218.1,CMD_SET_CTCSS_225.7=225.7,CMD_SET_CTCSS_229.1=229.1,CMD_SET_CTCSS_233.6=233.6,CMD_SET_CTCSS_241.8=241.8,CMD_SET_CTCSS_250.3=250.3,CMD_SET_CTCSS_254.1=254.1
BTN_OPT5_NOFN=DCS,CMD_SET_DCS_023=023,CMD_SET_DCS_025=025,CMD_SET_DCS_26=026,CMD_SET_DCS_031=031,CMD_SET_DCS_032=032,CMD_SET_DCS_036=036,CMD_SET_DCS_043=043,CMD_SET_DCS_47=047,CMD_SET_DCS_051=051,CMD_SET_DCS_053=053,CMD_SET_DCS_054=054,CMD_SET_DCS_065=065,CMD_SET_DCS_071=071,CMD_SET_DCS_072=072,CMD_SET_DCS_073=073,CMD_SET_DCS_074=074,CMD_SET_DCS_114=114,CMD_SET_DCS_115=115,CMD_SET_DCS_116=116,CMD_SET_DCS_122=122,CMD_SET_DCS_125=125,CMD_SET_DCS_131=131,CMD_SET_DCS_132=132,CMD_SET_DCS_134=134,CMD_SET_DCS_143=143,CMD_SET_DCS_145=145,CMD_SET_DCS_152=152,CMD_SET_DCS_155=155,CMD_SET_DCS_156=156,CMD_SET_DCS_162=162,CMD_SET_DCS_165=165,CMD_SET_DCS_172=172,CMD_SET_DCS_174=174,CMD_SET_DCS_205=205,CMD_SET_DCS_212=212,CMD_SET_DCS_223=223,CMD_SET_DCS_225=225,CMD_SET_DCS_226=226,CMD_SET_DCS_243=243,CMD_SET_DCS_244=244,CMD_SET_DCS_245=245,CMD_SET_DCS_246=246,CMD_SET_DCS_251=251,CMD_SET_DCS_252=252,CMD_SET_DCS_255=255,CMD_SET_DCS_261=261,CMD_SET_DCS_263=263,CMD_SET_DCS_265=265,CMD_SET_DCS_266=266,CMD_SET_DCS_271=271,CMD_SET_DCS_274=274,CMD_SET_DCS_306=306,CMD_SET_DCS_311=311,CMD_SET_DCS_315=315,CMD_SET_DCS_325=325,CMD_SET_DCS_331=331,CMD_SET_DCS_332=332,CMD_SET_DCS_343=343,CMD_SET_DCS_346=346,CMD_SET_DCS_351=351,CMD_SET_DCS_356=356,CMD_SET_DCS_364=364,CMD_SET_DCS_365=365,CMD_SET_DCS_371=371,CMD_SET_DCS_411=411,CMD_SET_DCS_412=412,CMD_SET_DCS_413=413,CMD_SET_DCS_423=423,CMD_SET_DCS_431=431,CMD_SET_DCS_432=432,CMD_SET_DCS_445=445,CMD_SET_DCS_446=446,CMD_SET_DCS_452=452,CMD_SET_DCS_454=454,CMD_SET_DCS_455=455,CMD_SET_DCS_462=462,CMD_SET_DCS_464=464,CMD_SET_DCS_465=465,CMD_SET_DCS_466=466,CMD_SET_DCS_503=503,CMD_SET_DCS_506=506,CMD_SET_DCS_516=516,CMD_SET_DCS_523=523,CMD_SET_DCS_526=526,CMD_SET_DCS_532=532,CMD_SET_DCS_546=546,CMD_SET_DCS_565=565,CMD_SET_DCS_606=606,CMD_SET_DCS_612=612,CMD_SET_DCS_624=624,CMD_SET_DCS_627=627,CMD_SET_DCS_631=631,CMD_SET_DCS_632=632,CMD_SET_DCS_654=654,CMD_SET_DCS_662=662,CMD_SET_DCS_664=664,CMD_SET_DCS_703=703,CMD_SET_DCS_712=712,CMD_SET_DCS_723=723,CMD_SET_DCS_731=731,CMD_SET_DCS_732=732,CMD_SET_DCS_734=734,CMD_SET_DCS_743=743,CMD_SET_DCS_754=754
BTN_OPT1_FN=VFO,CMD_SET_VFO_TOGGLE=AB
BTN_OPT2_FN=
BTN_OPT3_FN=SPLIT,CMD_SET_SPLIT_ON=ON,CMD_SET_SPLIT_OFF=OFF
BTN_OPT4_FN=RPT,CMD_SET_RPT_MIN=MIN,CMD_SET_RPT_PLUS=PLUS,CMD_SET_RPT_SIMPLEX=SIMPLEX
BTN_OPT5_FN=SHFT,CMD_SET_OFFSET_0100=100,CMD_SET_OFFSET_0600=600,CMD_SET_OFFSET_7600=7600,CMD_SET_OFFSET_1600=1600
; List of available commands for the current transceiver, all items from the list are bytes (reprezented as a HEX string
; use Pxxxx as 'byte' to separate two successive commands by a xxxx ms delay
; <Dxx> - numeric digits - BCD (from 9, thousands MHz to 0 - Hz)
; <Sx> - string digits - from 9 - , thousands MHz to 0 - Hz)
CMD_SET_FREQ=<D87>,<D65>,<D43>,<D21>,01
CMD_SET_SPLIT_ON=00,00,00,00,02
CMD_SET_SPLIT_OFF=00,00,00,00,82
CMD_SET_LOCK_ON=00,00,00,00,00
CMD_SET_LOCK_OFF=00,00,00,00,80
CMD_SET_PTT_ON=00,00,00,00,08
CMD_SET_PTT_OFF=00,00,00,00,88
CMD_SET_MODE_LSB=00,00,00,00,07
CMD_SET_MODE_USB=01,00,00,00,07
CMD_SET_MODE_CW=02,00,00,00,07
CMD_SET_MODE_CWR=03,00,00,00,07
CMD_SET_MODE_AM=04,00,00,00,07
CMD_SET_MODE_FM=08,00,00,00,07
CMD_SET_MODE_FM-N=88,00,00,00,07
CMD_SET_MODE_DIG=0A,00,00,00,07
CMD_SET_MODE_PKT=0C,00,00,00,07
CMD_SET_CLARIFIER_ON=00,00,00,00,05
CMD_SET_CLARIFIER_OFF=00,00,00,00,85
CMD_SET_VFO_TOGGLE=00,00,00,00,81
CMD_SET_DCS_ON=0A,00,00,00,0A
CMD_SET_ENCODER_ON=4A,00,00,00,0A
CMD_SET_ENCODER_OFF=8A,00,00,00,0A
CMD_SET_POWER_ON=00,00,00,00,00,<P1000>,00,00,00,00,0F,
CMD_SET_POWER_OFF=00,00,00,00,00,<P1000>,00,00,00,00,8F,<P1000>
CMD_SET_PWR_0.5W=
CMD_SET_PWR_1.0W=
CMD_SET_PWR_2.5W=
CMD_SET_PWR_5.0W=
CMD_SET_PWR_20.0W=
CMD_SET_PWR_45.0W=
CMD_SET_PWR_75.0W=
CMD_SET_PWR_100.0W=
CMD_SET_RPT_MIN=09,00,00,00,09
CMD_SET_RPT_PLUS=49,00,00,00,09
CMD_SET_RPT_SIMPLEX=89,00,00,00,09
CMD_SET_OFFSET_0100=00,01,00,00,F9
CMD_SET_OFFSET_0600=00,06,00,00,F9
CMD_SET_OFFSET_7600=00,76,00,00,F9
CMD_SET_OFFSET_1600=00,16,00,00,F9
CMD_SET_CTCSS_OFF=8A,00,00,00,0A
CMD_SET_CTCSS_ON=2A,00,00,00,0A
CMD_SET_CTCSS_RXON=3A,00,00,00,0A
CMD_SET_CTCSS_TXON=4A,00,00,00,0A
CMD_SET_DCS_RXON=0B,00,00,00,0A
CMD_SET_DCS_TXON=0C,00,00,00,0A
CMD_SET_CTCSS_67=06,70,06,70,0B
CMD_SET_CTCSS_69.3=06,93,06,93,0B
CMD_SET_CTCSS_71.9=07,19,07,19,0B
CMD_SET_CTCSS_74.4=07,44,07,44,0B
CMD_SET_CTCSS_77=07,70,07,70,0B
CMD_SET_CTCSS_79.7=07,97,07,97,0B
CMD_SET_CTCSS_82.5=08,25,08,25,0B
CMD_SET_CTCSS_85.4=08,54,08,54,0B
CMD_SET_CTCSS_88.5=08,85,08,85,0B
CMD_SET_CTCSS_91.5=09,15,09,15,0B
CMD_SET_CTCSS_94.8=09,48,09,48,0B
CMD_SET_CTCSS_97.4=09,74,09,74,0B
CMD_SET_CTCSS_100=10,00,10,00,0B
CMD_SET_CTCSS_103.5=10,35,10,35,0B
CMD_SET_CTCSS_107.2=10,72,10,72,0B
CMD_SET_CTCSS_110.9=11,09,11,09,0B
CMD_SET_CTCSS_114.8=11,48,11,48,0B
CMD_SET_CTCSS_118.8=11,88,11,88,0B
CMD_SET_CTCSS_123=12,30,12,30,0B
CMD_SET_CTCSS_127.3=12,73,12,73,0B
CMD_SET_CTCSS_131.8=13,18,13,18,0B
CMD_SET_CTCSS_136.5=13,65,13,65,0B
CMD_SET_CTCSS_141.3=14,13,14,13,0B
CMD_SET_CTCSS_146.2=14,62,14,62,0B
CMD_SET_CTCSS_151.4=15,14,15,14,0B
CMD_SET_CTCSS_156.7=15,67,15,67,0B
CMD_SET_CTCSS_162.2=16,22,16,22,0B
CMD_SET_CTCSS_167.9=16,79,16,79,0B
CMD_SET_CTCSS_173.8=17,38,17,38,0B
CMD_SET_CTCSS_179.9=17,99,17,99,0B
CMD_SET_CTCSS_186.2=18,62,18,62,0B
CMD_SET_CTCSS_192.8=19,28,19,28,0B
CMD_SET_CTCSS_203.5=20,35,20,35,0B
CMD_SET_CTCSS_206.5=20,65,20,65,0B
CMD_SET_CTCSS_210.7=21,07,21,07,0B
CMD_SET_CTCSS_218.1=21,81,21,81,0B
CMD_SET_CTCSS_225.7=22,57,22,57,0B
CMD_SET_CTCSS_229.1=22,91,22,91,0B
CMD_SET_CTCSS_233.6=23,36,23,36,0B
CMD_SET_CTCSS_241.8=24,18,24,18,0B
CMD_SET_CTCSS_250.3=25,03,25,03,0B
CMD_SET_CTCSS_254.1=25,41,25,41,0B
CMD_SET_DCS_023=00,23,00,23,0C
CMD_SET_DCS_025=00,25,00,25,0C
CMD_SET_DCS_026=00,26,00,26,0C
CMD_SET_DCS_031=00,31,00,31,0C
CMD_SET_DCS_032=00,32,00,32,0C
CMD_SET_DCS_036=00,36,00,36,0C
CMD_SET_DCS_043=00,43,00,43,0C
CMD_SET_DCS_047=00,47,00,47,0C
CMD_SET_DCS_051=00,51,00,51,0C
CMD_SET_DCS_053=00,53,00,53,0C
CMD_SET_DCS_054=00,54,00,54,0C
CMD_SET_DCS_065=00,65,00,65,0C
CMD_SET_DCS_071=00,71,00,71,0C
CMD_SET_DCS_072=00,72,00,72,0C
CMD_SET_DCS_073=00,73,00,73,0C
CMD_SET_DCS_074=00,74,00,74,0C
CMD_SET_DCS_114=01,14,01,14,0C
CMD_SET_DCS_115=01,15,01,15,0C
CMD_SET_DCS_116=01,16,01,16,0C
CMD_SET_DCS_122=01,22,01,22,0C
CMD_SET_DCS_125=01,25,01,25,0C
CMD_SET_DCS_131=01,31,01,31,0C
CMD_SET_DCS_132=01,32,01,32,0C
CMD_SET_DCS_134=01,34,01,34,0C
CMD_SET_DCS_143=01,43,01,43,0C
CMD_SET_DCS_145=01,45,01,45,0C
CMD_SET_DCS_152=01,52,01,52,0C
CMD_SET_DCS_155=01,55,01,55,0C
CMD_SET_DCS_156=01,56,01,56,0C
CMD_SET_DCS_162=01,62,01,62,0C
CMD_SET_DCS_165=01,65,01,65,0C
CMD_SET_DCS_172=01,72,01,72,0C
CMD_SET_DCS_174=01,74,01,74,0C
CMD_SET_DCS_205=02,05,02,05,0C
CMD_SET_DCS_212=02,12,02,12,0C
CMD_SET_DCS_223=02,23,02,23,0C
CMD_SET_DCS_225=02,25,02,25,0C
CMD_SET_DCS_226=02,26,02,26,0C
CMD_SET_DCS_243=02,43,02,43,0C
CMD_SET_DCS_244=02,44,02,44,0C
CMD_SET_DCS_245=02,45,02,45,0C
CMD_SET_DCS_246=02,46,02,46,0C
CMD_SET_DCS_251=02,51,02,51,0C
CMD_SET_DCS_252=02,52,02,52,0C
CMD_SET_DCS_255=02,55,02,55,0C
CMD_SET_DCS_261=02,61,02,61,0C
CMD_SET_DCS_263=02,63,02,63,0C
CMD_SET_DCS_265=02,65,02,65,0C
CMD_SET_DCS_266=02,66,02,66,0C
CMD_SET_DCS_271=02,71,02,71,0C
CMD_SET_DCS_274=02,74,02,74,0C
CMD_SET_DCS_306=03,06,03,06,0C
CMD_SET_DCS_311=03,11,03,11,0C
CMD_SET_DCS_315=03,15,03,15,0C
CMD_SET_DCS_325=03,25,03,25,0C
CMD_SET_DCS_331=03,31,03,31,0C
CMD_SET_DCS_332=03,32,03,32,0C
CMD_SET_DCS_343=03,43,03,43,0C
CMD_SET_DCS_346=03,46,03,46,0C
CMD_SET_DCS_351=03,51,03,51,0C
CMD_SET_DCS_356=03,56,03,56,0C
CMD_SET_DCS_364=03,64,03,64,0C
CMD_SET_DCS_365=03,65,03,65,0C
CMD_SET_DCS_371=03,71,03,71,0C
CMD_SET_DCS_411=04,11,04,11,0C
CMD_SET_DCS_412=04,12,04,12,0C
CMD_SET_DCS_413=04,13,04,13,0C
CMD_SET_DCS_423=04,23,04,23,0C
CMD_SET_DCS_431=04,31,04,31,0C
CMD_SET_DCS_432=04,32,04,32,0C
CMD_SET_DCS_445=04,45,04,45,0C
CMD_SET_DCS_446=04,46,04,46,0C
CMD_SET_DCS_452=04,52,04,52,0C
CMD_SET_DCS_454=04,54,04,54,0C
CMD_SET_DCS_455=04,55,04,55,0C
CMD_SET_DCS_462=04,62,04,62,0C
CMD_SET_DCS_464=04,64,04,64,0C
CMD_SET_DCS_465=04,65,04,65,0C
CMD_SET_DCS_466=04,66,04,66,0C
CMD_SET_DCS_503=05,03,05,03,0C
CMD_SET_DCS_506=05,06,05,06,0C
CMD_SET_DCS_516=05,16,05,16,0C
CMD_SET_DCS_523=05,23,05,23,0C
CMD_SET_DCS_526=05,26,05,26,0C
CMD_SET_DCS_532=05,32,05,32,0C
CMD_SET_DCS_546=05,46,05,46,0C
CMD_SET_DCS_565=05,65,05,65,0C
CMD_SET_DCS_606=06,06,06,06,0C
CMD_SET_DCS_612=06,12,06,12,0C
CMD_SET_DCS_624=06,24,06,24,0C
CMD_SET_DCS_627=06,27,06,27,0C
CMD_SET_DCS_631=06,31,06,31,0C
CMD_SET_DCS_632=06,32,06,32,0C
CMD_SET_DCS_654=06,54,06,54,0C
CMD_SET_DCS_662=06,62,06,62,0C
CMD_SET_DCS_664=06,64,06,64,0C
CMD_SET_DCS_703=07,03,07,03,0C
CMD_SET_DCS_712=07,12,07,12,0C
CMD_SET_DCS_723=07,23,07,23,0C
CMD_SET_DCS_731=07,31,07,31,0C
CMD_SET_DCS_732=07,32,07,32,0C
CMD_SET_DCS_734=07,34,07,34,0C
CMD_SET_DCS_743=07,43,07,43,0C
CMD_SET_DCS_754=07,54,07,54,0C
; read command format
; <priority>,<when to read>,<command - variable length>,<separator>,<nr.of.expected.bytes>,<rec_byte_1>,...,<rec byte_n>
;       <priority> - 01-each loop, 02-from time to time (currently one from 4 loops)
;      <when to read> - 00-both during Rx and Tx, 01-during Rx only, 02-during Tx only (discarded/not sent otherwise)
;      <command - variable length> - see list of available commands format above (same as for the "blind commands", with no feedback)
;      <separator> - <R> - end command separator (<R>)
;      <nr_rec_bytes> - number of data bytes expected to be received
;      <rec_byte_x> - what that byte represent
;                - follows the rule from the SEND commands to define data
;                - <00> - byte not containing a farameter to be read - will be discarded
;                 - list of possible byte value (as 2 digits hex if numeric value or Sx if char value) and corresponding parameter value. Take care to use a valid parameter value, this is not checked for errors.
;                  A binary byte followed by '/' can be used as a mask for that byte if only some bits are to be used
CMD_READ_FREQ&MODE=01,01,00,00,00,00,03,<R>,05,<D87>,<D65>,<D43>,<D21>,<00=LSB;01=USB;02=CW;03=CWR;04=AM;06=WFM;08=FM;0A=DIG;0C=PKT>
CMD_READ_VFO=04,01,<RE0055>,<R>,02,<xxxxxxx0=VFO-A;xxxxxxx1=VFO-B>,<xxxxxxxx>
CMD_READ_SMETER=01,01,00,00,00,00,E7,<R>,01,<xxxx0000=S0;xxxx0001=S1;xxxx0010=S2;xxxx0011=S3;xxxx0100=S4;xxxx0101=S5;xxxx0110=S6;xxxx0111=S7;xxxx1000=S8;xxxx1001=S9;xxxx1010=S9+10dB;xxxx1011=S9+20dB;xxxx1100=S9+30dB;xxxx1101=S9+40dB;xxxx1110=S9+50dB;xxxx1111=S9+60dB>
CMD_READ_PWR=01,02,00,00,00,00,BD,<R>,02,<vvvvxxxx>,<xxxxxxxx>
CMD_READ_ALC=01,02,00,00,00,00,BD,<R>,02,<xxxxvvvv>,<xxxxxxxx>
CMD_READ_SWR=01,02,00,00,00,00,BD,<R>,02,<xxxxxxxx>,<vvvvxxxx>
CMD_READ_MOD=01,02,00,00,00,00,BD,<R>,02,<xxxxxxxx>,<xxxxvvvv>
CALIB_SMETER=
CALIB_PWR=<MAX=0F>,<0=0;07=2.5;0F=5>
CALIB_SWR=<MAX=0F>,<00=1;02=1.1;04=1.2;05=1.5;06=2;08=3;09=5;0B=10>
CALIB_ALC=<MAX=0F>,<0=0;07=50;0F=100>
CALIB_MOD=<MAX=0F>,<0=0;07=50;0F=100>
;CMD_READ_SQUELCH=0A,05,01,00,00,00,00,E7,<R>,<01>,<10000000/01=ON;10000000/00=OFF>
; list of commands to be sent at startup (optional)
STARTUP=CMD_SET_PTT_OFF,CMD_SET_LOCK_OFF,CMD_SET_PARAMS_FROM_INTERFACE
; list of commands for the parameters feedback
POLLING=CMD_READ_FREQ&MODE,CMD_READ_PTT,CMD_READ_VFO,CMD_READ_SMETER,CMD_READ_SWR,CMD_READ_PWR,CMD_READ_ALC,CMD_READ_MOD
; list of commands to be sent at startup (usually read different parameters in order to be able to work after that without feedback, for max. responsiveness
STARTUP=CMD_READ_FREQ,CMD_READ_MODE,CMD_READ_MODE,CMD_READ_MODE,CMD_READ_MODE
Thank you for the update. Is now in the repository too.
Please do a small correction in your config. Delete the space(blank) at the end of the following line:
On some versions of the application this space make the application not to load the radio picture.
Thank you for your continuous support.
Best regards,
ok thanks
Deleted the Space. I guess in the Repository you already corrected it
MysticFire wrote: I guess in the Repository you already corrected it
Yes...:-)
Yaesu FT-950 config is now available in the repository.
If someone is able to test it I kindly ask him to send me some feedback.
Hi everyone. Is there a way to change step in kHz for a particular Band
