Experimental Pocket RxTx version (0.9) & jAReC 0.9
KG5FBO
Re: Experimental Pocket RxTx version (0.9) & jAReC 0.9
Post by KG5FBO »
I just downloaded a new config file and will give it a try in a little bit. I will post the results of my test.
Same problem the radio locks up during the initiation and the audio stops.
I did go back and try version 8 and it still work fine.
KG5FBO wrote:I just downloaded a new config file and will give it a try in a little bit. I will post the results of my test.
I will check tomorrow (now is 1:11pm here) with my FT-991 and be back.
Thank you for your report.
Hello Thanasis,
sv3aqt wrote:Dan Hi
The mobile app does not seem to respond in my mobile while the v 8 works fine and also the previous experimental v9.0.1 was working ok.
Can you please detail a little bit? What do you mean by "the mobile app does not respond"?
sv3aqt
Post by sv3aqt »
Dan Hi
The app on my mobile v 9.0.16 was completely unresponsive. The application switches on but all the buttons did not respond at all.
I did unintelligible it and install back the v9.0.11.
Now everything works perfectly fine.
Is there something I am doing wrong?
73 Thanasis SV3AQT
Hi Thanasis,
Have you ckecked that the interface is not locked? I have no other reports that the interface locks, nor able to replicate this behavior here.
By "the buttons did not respond" do you mean that even the status in the interface does not change when you press a button?
You are using jAReC version 0.9.0-16?
Can you post a screenshot of the main screen when radio is on?
KG5FBO wrote:I have installed the 16 version and use it for a FT-991. When it first starts I have audio, but before the initialization is complete (a matter of seconds) the audio stops and the radio is hung up. I have to turn the radio off and on to recover. I have not had time to really look at the cat commands being issued. I did do the long press on the start button to load the new config file. Feel free to send email for faster response.
I was not able to replicate your issue. I'm using Pocket RxTx 0.9.0-16, jAReC 0.9.0-16 and my FT-991 with the internal CAT interface connected over USB to the PC where jAReC runs, with the latest "Default" config for FT-991 available in the central repository.
Can you please send me more details about your setup?
FT-991 menu setup for the following parameters:
- 031 CAT rate
- 032 CAT TOT
- 033 CAT RTS
- 062 DATA MODE
- 071 DATA PTT ELECT
- 072 DATA PORT SELECT
A screenshot with the jAReC Panel or a copy of the jAReC configuration file (jsn.cfg)
A copy of the Windows Devices window, expanded with the COM ports (to see the two COM ports created by the FT-991).
This is all for the moment.
sv3aqt
Post by sv3aqt »
I have tried once again with v9.0.16. Same thing.
The radio switches on but the the application on the phone is not responding. It looks like the interface is frozen. Pressing the buttons on the phone does nothing, The wheels for power and mode do not move and in general all buttons do not respond.
I am not sure if you have changed some parameters and may be the .radio file configuration needs to be changed too.
I have reverted back to the v 9.0.11 which works perfectly.
73s Thanasis SV3AQT
sv3aqt
Post by sv3aqt »
I forgot to say..Yes I am using Jarec v 9.0.16
73s Thanasis SV3AQT
Hello Thanasis,
Is feedback activated in Pocket RxTx?
I really want to understand where the issue is.
sv3aqt
Post by sv3aqt »
Dan,
I am not sure how exactly you can activate feedback in pocket rxtx.
Thanasis
