Page 7 of 13
Posted: Fri Oct 21, 2016 9:27 pm
by pa3vos
I did remove everything but it still get freezing screen. just a minute ago audio was also running but the rig was set to AM mode and none of the button react. I received a error message that popped up. I made a screen shot. I attach it to my post
I will try again to remove all files again and reinstall the program
regards,
Fokko
Posted: Fri Oct 21, 2016 9:44 pm
Starting with version 0.9.0-16 you don;t need to reinstall the app. A full reset is now equivalent with a cleanup and reinstall. At first start you are asked which mode to be the default one (WebSDR or Direct CAT).
When do you get that error?
Posted: Sat Oct 22, 2016 3:04 pm
by pa3vos
I can not recall exactly after what action I got the message.
And yes I received the selection option regarding CAT or Web SDR. I also see the hardbeat running well. left the small yellow/orange dot en right the green dot. but the app doesn't sync with the RIG. the RIG is set to 0.030 MHz in LSB and I heard noise. But non of the buttons are working however if I touch a button I see the green dot acting.
I tried several times a clean reinstall so I all removed manually ALL related files that where still in the rxtx folder.
Non worked for me however yesterday one time it worked for about 10 minutes and then it got froozen.
73's Fokko
Posted: Sat Oct 22, 2016 3:17 pm
by pa3vos
Additional information: I reinstalled the previous version and this works great again. but with jAReC 0.9
Posted: Sat Oct 22, 2016 3:34 pm
by pa3vos
After installing the version 0.8 I installed the version 0.9 just to see what would happen.
I had audio but the RIG was set to LSB. frequency was not changed and non of the buttons act on touching. once again haertbeat yellow and green wher eblinking.
after leaving the program I received beliwe message.
Posted: Sat Oct 22, 2016 4:12 pm
Hi Fokko,
Do you mean that after installing 0.9.0-16 the version 0.8.x-x does no more work as expected, or the issues are with 0.9.0-16 only?
Posted: Sat Oct 22, 2016 8:18 pm
by pa3vos
0.8 works perfect but 0.9 does not work properly
Fokko
Posted: Sat Oct 22, 2016 8:29 pm
Hi Fokko,
Please give me more details about the Android version and your device.
Posted: Sun Oct 23, 2016 12:56 am
by pa3vos
My device is still the same a Samsung S5
Android version 5.0.1
Fokko
Posted: Sun Oct 23, 2016 11:19 am
Hello Fokko,
I've tried on my LG G3 with Android 5.0 and I cannot replicate your problem. Please give me the exact steps to get that error.
