Yaesu radios config files
Skyseek
Re: Yaesu radios config files
Post by Skyseek »
Does anybody know the CAT command for the FT-991A to enable WiresX? In the FT-991A CAT manual on Page 7
Under the EX MENU
EX MENU O O O O
150 PRT/WIRES FREQ 0: MANUAL 1: PRESET 1
151 PRESET FREQUENCY 00030000 ~ 47000000 8
152 SEARCH SETUP 0: HISTORY 1: ACTIVITY 1
153 WIRES DG-ID 00: AUTO 01: DG-ID 01 ~ 99: DG-ID 99
CAT Manual
I would really like to update the repository Yaesu FT-991A config file with WiresX functionality
Reference : https://www.google.com/url?sa=t&rct=j&q ... 821FOm_lHj
I'm not familiar with WiresX operation. Please detail a little bit the exact sequence of commands you want to send.
Skyseek wrote: Sat Dec 16, 2017 10:21 pm Does anybody know the CAT command for the FT-991A to enable WiresX? In the FT-991A CAT manual on Page 7
Under the EX MENU
EX MENU O O O O
CAT Manual
Skyseek
Post by Skyseek »
See YouTube Video:
https://www.youtube.com/watch?v=f4hGX9wKVAE
Thanks!
yo7lti
Post by yo7lti »
Please help me,
I tried Pocket RxTx with my FT-817 via usb and bluetooth connections. I increased bluetooth speed at 38.400 and works just fine. I have some issue with some commands such Att on/off. Looking in the radio config. file I saw that command Att on/off is defined but the opcode is not present. User manual refers only to 17 commands and I hope someone would help me to find the opcode for att on/off and maybe other undocumented commands(IPO???)
Mny tnx, Ovidiu
Hi Ovidiu,
If you take a look here:
http://www.ka7oei.com/ft817_meow.html
The problem is that this setting is per band, so you must define one command per each band.
G4GOU
Post by G4GOU »
I have an FT950 and noticed that in the config file that the command for setting the power level was incorrect and that the rig did not switch off, I have amended the configuration and also enabled the S Meter and added commands to control bandwidth and renamed DATA and USER modes to RTTY and PKT - to use the rear data connection for audio the mode should be set to PKT-U or PKT-L
the file is available here https://spain.wizgnome.com/owncloud/ind ... gMNd2vAmGn
Mike
G4GOU
Scott
Need Working Config for Yaesu FT-857
Post by Scott »
First of all, the Pocket RXTX app is really cool, but...
I tried the 2 Configs (Default and Anton) for the Yaesu FT-857 and they work for the most part but a lot of buttons are missing...
1. I really need the "TUNE" button so I can tune my ATAS 120 Antenna.
2. "Power ON/Off" will not power on/off the radio.
3. Can not change output power (watts).
4. DNR
5. NB
6. AGC
7. IPO
8. ATT
the list goes on......
NEED GOOD CONFIG PLEASE
Thanks,
Scott
SY1DAL
Post by SY1DAL »
Hi to all .
Here is my custom version for Yaesu FT-450/D which is also in the main repository online.
It covers everything needed for this radio and works very accurately.
Best 73s
yaesu_ft450.zip
(2.7 KiB) Downloaded 569 times
https://qrz.com/db/sy1dal
.:: Jimmy Sy1Dal ::.
SY1DAL
Post by SY1DAL »
Hi to all .
Best 73s
yaesu_ft450.zip
(2.7 KiB) Downloaded 558 times
test post to check permissions
