miniVNA Pro support
miniVNA Pro support
Let's discuss here all the topics related to miniVNA Pro and the Android application.
In this moment (Aug 17th 2012) miniVNA PRO is not yet supported, but with your help I hope to be in the near future.
ZS1RS
Re: miniVNA Pro support
Post by ZS1RS »
Hi Dan
Will you be supporting the Extender at a later date
Colin
ZS1RS
Hi Colin,
Yes, I intend to support the extender too and to add new features to the current version of the app.
In a few day, if current beta version will be stable enough, I will push it through Google Play.
ZS1RS
Post by ZS1RS »
Hi Dan
Just a thought...I know you can see it on the screen, but as you have a minimum SWR block already
Could a 2:1 bandwidth block be added, sort of like the manufactures specify (I think it 2:1 SWR the bandwidth is done at)
I still have to read up on this new toy so I can find resonance with it not lowest swr...
ZS1RS
Hi Colin,
Yes, I can. I will do it in the next release together with some other features.
As soon as the application will be available in Play Store will be much easier to upgrade to new versions, which will follow.
Thank you for the idea.
vk5alx
Post by vk5alx »
Hi Dan
Downloaded v0.5.5 from the play store but now can not get the graph zoom and scroll to work.
Have reinstalled v0.5.1 which works fine.
73, Alex
UPDATE:
Installed on my Galaxy S2 and it worked OK so I did a fresh install on the Nexus 7 and this time it works fine.
Comment: Even with font size increased I found the floating grey box with various parameters - min swr etc - still a bit small. Gave the box a tap and wow the info comes up in large text. GREAT! What other surprises are there to find.
cheers, Alex
Hi Alex,
As stated in the latest version of the documentation, the version in Play Store is signed with a valid key, so you have to uninstall any previous version before installing this one.
Each of your findings are already explained in the manual, so no surprises at all (for the moment) ...:-)
I'm glad that is working for you now.
Can you please send me a screenshot with the Startup page and in Antenna mode to better see how the fonts look on your device?
I've seen some issues with Galaxy Note devices where you cannot increase the font size enough because of a very big displayed checkboxes.
I want to see if I can correct this in hardware.
pb3sm
Post by pb3sm »
Dan,
I fell for a Galaxy Note 10.1, for which Samsung has a special cashback deal for Christmas. I need to learn it all, but I have made some measurements with the miniVNA Pro hanging at the feed point of my Cushcraft R7. It looks impressive and congratulations for a great job done. I am not planning to use an Extender, since I am a straight HF ham. :D :D :D
73,
Kjell, PB3SM - SM6CPI
Thank you Kjell,
OE3DBW
Post by OE3DBW »
I use a Samsung Galaxy III with your SW V0.6 and I get the Error
An Error has occurred in sub:main_grahrefresh (java line: 7526)
java.lang.RuntimeExceptio: Object shouldfirst be initialized)Label)
Did you forget to call Activity. Loadlayout?
Continue?
If I press Yes, then I come back, but no CAL is possible
If I press No, the aplikation close
???? What can I do ???
73 de Ferdinand OE3DBW
