How to look at the .vec files?
sm3sgp
Post by sm3sgp »
How can I use the .vec files I saved with the android app?
In the new vna/J java program I don't see any way to load .vec files, and I cannot find the old software referred to in the manual.
73 de Gunnar SM3SGP
Re: How to look at the .vec files?
Hi Gunnar,
Unfortunately in the current version of BlueVNA you can load on a PC only the vec files saved for miniVNA standard(non Pro), using the miniVNA by IW3HEV v > 2.3 Windows application.
In a future version you will be able to save in csv format and then load in Z-plots or other similar PC application.
Sorry for the inconvenience.
sm3sgp
Post by sm3sgp »
Thanks for a great program. I used the vna together with your app up in the tower today. Measured the new 4 stack for 15m at SK3W. Maybe possible to make some kind of screenshots and save in the android. I will play a bit...
Hi Gunnar,
Please send some vec files with your captures to be added to the samples page.
Thank you for your feedback,
