I just followed you over here from the post(s) you were posting on HRD Forum.
I'm looking foward to see what you develope here.
John
KW7A
Utah, USA
HRD & Android
Re: HRD & Android
Hi John,
Thank you for joining this list.
I will post any future updates here and I hope that users will post their findings here too.
Re: HRD & Android
Hi Dan;
While exercising a fresh install of PocketRXTX v0.5 on my HTC One X I ran into a few problems. Mostly pleased with the app, though. I am using an IC-718 connected to my HP G62 Win 7 laptop via a BlackCat USB to C-IV interface and using HRD 5.24.0.36
1. Changes from portrait to landscape or landscape to portrait causes the VFO displayed to change to VFO B if set on VFO A. The change is not made on the radio. This does, however, lock out the VFO change button.
2. I get no gray slider tab as described in the documentation. Is that just for the SDR operation?
3. Working the tuning knob too fast causes 0.0320 MHz to display on the app. Sometimes (not reliably repeatable) this change makes it to the radio. When it does make it to the radio, it locks the radio up. A soft reset of the radio and re-start of the app was required to clear the issue.
4. App display always starts and stays in VFO B no matter what VFO is set on radio. Only changes when you change the VFO from A to B to A in the app.
5. App display starts in last selected mode when radio is in any mode. (i.e: Radio set to USB manually after remote set to RTTY, app display stays in RTTY when re-started.)
6. See #5 above but related to the RF power setting.
Thanks for activating my user account, Dan.
Rob Kirk
AB0RK
ARRL Member
EM27rb
"TANSTAAFL!" - Anon
AB0RK
ARRL Member
EM27rb
"TANSTAAFL!" - Anon
Re: HRD & Android
Hi Rob,
0.0320 is displayed when HRD return value '0' for frequency when queried.
I think I'm pushing to far in the communication with HRD IP Server. I'm still searching for a workaround.
I will correct this in the next version.rkirk1507 wrote: 1. Changes from portrait to landscape or landscape to portrait causes the VFO displayed to change to VFO B if set on VFO A. The change is not made on the radio. This does, however, lock out the VFO change button.
What do you mean by gray slider? If you talk about the one on top then is just for SDR mode, to activate waterfall or spectrum display.2. I get no gray slider tab as described in the documentation. Is that just for the SDR operation?
It seems to be something related to HRD,3. Working the tuning knob too fast causes 0.0320 MHz to display on the app. Sometimes (not reliably repeatable) this change makes it to the radio. When it does make it to the radio, it locks the radio up. A soft reset of the radio and re-start of the app was required to clear the issue.
VFO is not fully functional yet for all radios. There is no feedback (except at startup), is more like a blind toggle if the sync is lost.4. App display always starts and stays in VFO B no matter what VFO is set on radio. Only changes when you change the VFO from A to B to A in the app.
I don't think I understand very well this...can you explain a little bit more?5. App display starts in last selected mode when radio is in any mode. (i.e: Radio set to USB manually after remote set to RTTY, app display stays in RTTY when re-started.)
Same here.6. See #5 above but related to the RF power setting.
Sorry for the delay, but as I told you, a lot of spam robots tries to register automatically and I cannot discern between a robot and a legitimate request, so I've decided to accept only registrations done using the callsign or with a direct mail in parallel to warn me.Thanks for activating my user account, Dan.
Re: HRD & Android
Dan;
About #5 & #6 - After using PocketRXTX, if you change the mode manually (locally) with the app off line then the app dosen't read the the radio operating mode correctly. Same for RF power setting. I suspect this is related to your response to #4: "There is no feedback (except at startup), is more like a blind toggle if the sync is lost." The last set mode and power sent are retained by the app and displayed.
Rob Kirk
AB0RK
ARRL Member
EM27rb
"TANSTAAFL!" - Anon
AB0RK
ARRL Member
EM27rb
"TANSTAAFL!" - Anon
Re: HRD & Android
I can add VFO and Power too, but this will decrease the update speed for frequency and mode.
I will make some tests to see if de introduced delay is acceptable.
What do you mean "with the app offline? The only parameters which are read continuously from the radio are frequency, mode, PTT status and S value.rkirk1507 wrote:Dan;
