Pocket RXTX version 0.4.1-3 available for download
Version 0.4.1-3 is available for free download in Play Store.
What's new from 0.4:
- feedback for PTT and S-Meter added in HRD mode;
- support extended to more functions/transceivers (see the table below);
- cannot change mode because of feedback from transceiver;
- in HRD mode the power is not read correctly at startup;
- if Off and then On does not connect anymore to HRD (need to restart app);
- do not keep mode and bandwidth settings when rotating in SDR mode;
- sound dropouts and random disconnections in SDR mode.
Please post your feedback regarding bugs or new features in this forum.
The development depends on YOU.
Re: Pocket RXTX version 0.4.1-3 available for download
Version 0.6 is available in Play Store for update/download.
What's new comparing with 0.5.x:
- multi SDR servers support;
- Slow AGC for waterfall (better constrast without fast changes);
- High/Low quality for Waterfall/Spectrum
- use camera hardware button (if available) as PTT;
- IC-7000 support;
- when you manually edit the frequency the display is cleared at firs key press;
- permanent feedback added for VFO and Power.
Bug fixes (I hope):
- USB symbol remains when starting in FT8x7 mode even if USB is not activated;
- incorrect UTC time if timezone is negative.
- PTT does not work for TS-2000;
- crash if no usb host support available on the smartphone/tablet with os version 2.3.x;
- bands not saved/recalled when changing memories;
More details in the updated application user guide.
As usual, I kindly ask you to send me your feedback.
This is now an old version.
Please use 0.6.4
