hi Dan
thank you for the video with recalling the memories. On my device it does not work like in yours. Maybe it is a buffer overflow. My BT device is fixed to 4800 Baud, I cannot change this. Maybe the sequence is sent to fast for my device and the mode change is dropped?
73!
Werner oe9fwv
Memory does not change mode
Re: Memory does not change mode
Hi Werner.
The way send commands is implemented in the app prevents the situation that a new command is send before the previous one was executed.
All are pushed to a queue of commands.
I would like to see if other users reports the same problem as I cannot replicate here.
what is the Baudrate of your BT device? Can you change it to 4800?
Default baud rate for the BT module is 9600.
Mine is configured at 38400, maximum possible for CAT.
