Is there anyfix for this?
I tried different os`s and computers as soon as there is a comport in the machine
i end up with this error run-time error '380': invalid property value.
A computer without a comport wich is offcourse useless with this
program does start up with no error.
Help please
regards,
Barry
Re: run-time error '380': invalid property value
Hi Barry,
I've received your e-mail too, but I will answer here in order for other users to be able to see the answer.
Please tell me on which OS'es have you tried the application.
The application does not work on Windows Vista or Windows 7, only on XP. Another limitation is that it can see only COM ports with a number < 9.
Usually you can change the COM port number in the OS to make it < 9.
On the other side, it works in an XP virtual machine under VMWare Player installed on Windows 7 Enterprise 64 bit (this is my current configuration here).
Best regards,
Best regards,
Thx for your answer i tried with win732b and winxp32b with sp3 a no go even with com 1 till 6
remarkable thing was when i don`t have a comport installed the spca starts even with win7
when i activate a comport and restart the program it gives the same error
I didn`t try with vmplayer that will be my next option so i don`t have to worry about a driver
not found.
I guess winxpsp3 wont be a problem or does it need to be plain winxp?
regards
Barry
not found.
regards
Barry
Hi Barry. It must work with any version of XP, I will take a look today and be back.balans wrote:I guess winxpsp3 wont be a problem or does it need to be plain winxp?
The fact that you don't get the error when there is no COM port available is a good information.
Hi Barry,
You can download SPCA version 1.1.1 from here:
http://www.yo3ggx.ro/spca/spca1.1.1.zip
Please change the extension from ex_ to exe.
It must work now on Windows 7 too.
Please check it and send me your feedback.
Best regards,
Best regards,
I was just writing a message saying vmware solution works
I found out that the version i downloaded within vmware was a newer version
i can confirm it also works now with windows 7 32bits sp1.
now see if i can program the bleutooth dongle.
Thx for the service , great idea and a great program
best regards,
Barry , pa1zkh
best regards,
Barry , pa1zkh
Hi Barry,
Glad to hear that it works for you now.
Yes, you can use SPCA to program the Bluetooth dongle. Be aware that the default baudrate for the BT module is 9600.
Good luck,
Good luck,
Works on Windows 10 too!
Very nice program. Small and portable.
Great for testing transceivers.
RJ
RJ
An Android version of jAReC will be available soon. This will allow you to use a cheap old smartphone at home instead of a PC to remotely access your transceiver over Internet from Pocket RxTx. More details will follow.
