How do I change the Call sign that show up on webSDR on V6
ZR6AIC
Post by ZR6AIC »
Hi
How do I change the call sign that show up on webSDR with V6 (running on Galaxy S2)
Regards
Anton
Re: How do I change the Call sign that show up on webSDR on
Hi Anton,
What do you mean by "change the callsign"?
sm4jlx
Post by sm4jlx »
I think Anton says that when you connect your Pocket RXTX against a WebSDR server so it will come up the name of the model of Android phone that you use.
In my case, I have a Samsung GT9100 phone.
When you look at an WebSDR server from a computer so you can see who is online on the currently assigned its call sign, or so it comes up an IP address.
But from my Samsung it says "@ GT-I9100@6.4", you can not even see the town.
Good if in Pocket RXTX could indicate their call sign which then appeared on WebSDR server.
73 the SM4JLX / Inge
Hi Inge,
That info is hardcoded in the app for the only reason to know the device and the app version the user is using.
I will change this to be able to add the callsign to the hardcoded info.
