BlueVNA beta version 0.7.3
A beta version of BlueVNA (0.7.3-3) is now available in Play Store. To become a beta tester for any of my apps, you just have to join the following Google Group:
https://groups.google.com/forum/?fromgr ... o3ggx-apps (YO3GGX's Android apps)
To be able to download it please go to the following link and accept to become a tester specifically for this app.
https://play.google.com/apps/testing/ro.yo3ggx.btvna
If you want to revert to the production version (0.7), access the same link again and choose to leave the test.
What's new in 0.7.3-3 comparing with 0.7:
- experimental usb support added for both miniVNA standard and Pro, with the condition that the Android device is able to power up the miniVNA over USB;
- button added to display all menu items in the same time on the screen;
- extended preset frequency range for each band. You can zoom for more details;
- ask to enable Bluetooth at startup if disabled;
- the vertical marker follows frequency when zoming or shifting;
Solved bugs:
- incorrect phase in miniVNA Pro mode.
- if switch from Extender to non-Extender old frequency range is keept (which can be out of band);
- shift modify zoom in low zoom circumstances;
Please send me any feedback you may have for the beta version using this topic.
Thank you and best regards,
Barry
Re: BlueVNA beta version 0.7.3
Post by Barry »
I did get 7.3-3 BlueVNA from the Play Store.
I connect MiniVNA via USB cable to ASUS TF300T and it asks if I would like to open BlueVNAnew
I select OK and am told to connect OPEN reference to DUT connector. I thinks that just means no connection to DUT or DET. I select OK and it sticks on open calibration.
best regards
Barry
VA7GM
Hi Barry,
It is an issue with the USB library in this version. I will post tomorrow an updated version which was tested and works with miniVNA standard over USB.
I will post a message here when available.
