Pocket RXTX 0.6.4 now available in Play STore
A new version of PocketRXTX (0.6.4) is now available for download in Play store.
What's new in 0.6.4.comparing with the old 0.6:
- fully redesigned SDR routines to allow playback on low performance Android devices too (ex. WM8650);
- save/load config and/or memories to a file;
- automatically load memories and last frequency per WebSDR server, if a file exist with the server callsign name;
- memories are now separate per operation mode (SDR/HRD/FT8x7) and saved to external files, not internally;
- second location for servers master data, for redundancy;
- display bandwidth in SDR mode;
- better handling of waterfall AGC;
- automatically set the default font size independent on the device type/model (font size no more dependent on system font size settings);
- easier procedure to set font size if the default one is not acceptable;
- toast message to long press on Power in order to start;
- Waterfall AGC active only when no zoom active;
- Up/DOWN steps are now aligned at first press (useful when changing channels in VHF/UHF bands) .
- 11m Band button does not work;
- cannot access 2m and 70cm bands in HRD mode (IC-7000).
Online multilanguage help is available here:
http://www.yo3ggx.ro/pocketrxtx/doc07/index.html
Offline help (pdf) is available here
http://www.yo3ggx.ro/pocketrxtx/doc07/p ... x_v0.7.pdf
Please send me your feedback if you have the time to play with the new version.
The help in the app and the online one are updated, so please read it to better understand the new features. You can revert at any time to the public version by just accessing the same link and click on "Leave the test".
Thank you all for your continuous support.
