Newest update No HRD?
Posted: Wed Aug 27, 2014 1:04 pm
When I updated to the latest greatest all my connection info was lost, and I cannot find how to connect to HRD. Everything was working fine prior to the newest update. Any insight?
We will discuss here only the projects presented on my web page (https://www.yo3ggx.ro)
https://forum.yo3ggx.ro/
Hi,N9MXQ wrote:Didn't see it mentioned anywhere.. And if I have to install more software then it's not worth it. It was fun while it lasted
Till feedback will be available, as FT8x7 uses several settings on a single data byte, you need to edit config file to accomodate your own needs.iw1ghg wrote: 1: When you log on to the network is automatically selected the antenna front (FT817)
This is by design. You don't have to use setup when the transceiver is ON. First set and then power on.2: When you click on setup, the radio turns off
In the current version step (for +/- buttons ) is automatically set based on bad used. For fine tuning use the knob.3: there is no way to set the step, sometimes at 6.25 kHz VHF goes sometimes at 1 khz
