Java.io error FileNotFoundException
Plwase post here all the bugs you found in the app.
Sometimes when you start the app, especially if you done an upgrade from the previous version, you can get the following error (or similar):
An error has occured in sub:
java.io FileNotFoundException: /storeage/emulated/0/prxtx/Radios/k3.jpg: open failed: ENOENT (No such file or directory)
Continue?
This error is most probable related to a "feature" requested by many users: prevent adding radio pictures to the media library.
Please do the following:
- uninstall the application
- completely remove the folder "/prxtx" from the Internal Storage (using a file explorer or connection the device to a PC)
- reinstall the application
- restart the device.
Hope this helps.
Please send me your feedback after you try this. I intend to remove this feature in the next release which is a work in progress.
