746Pro and IC7000 go into transmit...
kr3no
Post by kr3no »
Using the latest version of the Program 0.7.1 the radios (both) go into transmit immediately upon pressing the ON button. I've uninstalled and re-installed the application and tried two different computers.
Re: 746Pro and IC7000 go into transmit...
Firs sorry for the late reply, but I ws not notified about a new post.
For ICOM transceivers you need to see if the radio address in the configuration file is the same as the one set in your radio.
If yes, then I will ask you to further check other possible causes.
