How use other port com to PTT ?
SQ7OVT
Post by SQ7OVT »
Hi, I have TS-570 and conect to pocket txrx via CAT com 1 and for me important use audio via com 2.
How config PTT buton?
Re: How use other port com to PTT ?
Audio is not supported in the current version of the application.
I don't understand what do you mean by "How config PTT button".
Can you please detail a little bit?
SQ7OVT
Post by SQ7OVT »
Dan about new version you write
"...- Audio experimental support..." because I thought that in this version of the audio test already works both ways.
Speaking about the second com port I mean such a solution as it is for me with HRD and Digital Master 780, CAT connects to the COM1 and to make it PSK audio socket connected to COM2 ACC2 and all audio in both directions for me is connected by ACC2 so by pressing the PTT pocketRXTX would like to open the PTT and COM2, COM1 starts now my microphone socket on the front radio.
73's
SQ7OVT wrote:Dan about new version you write
This was the way supposed to work, but it seems to be an issue with the audio from smartphone to the transceiver. I' still working on this.
73's
For the moment PTT in jAS2SecNET is supported only as a CAT command, not a separate signal.
