Server update
Here we will discuss general topics related to other potential hardware or software projects
Server update
Hi everybody.
Today I've updated the server hardware and software, including phpBB.
You must see a significant improvement in speed.
If something does not work as expected, please send me a mail.
Bas
Re: Server update
Post by Bas »
Did you change the Mysql/MariaDB parameters like keybuffer and such?
Those make a very big difference in speed.
I can give you many hints as the default settings are very poor and mostly enough for home-user use, but not for a public forum.
Re: Server update
Hi Bas,
This is a very old post. Did you observed any performance issues with this forum?
Bas
Re: Server update
Post by Bas »
Yes I do as it takes quite a bit of time before the forum responding to command, but when it does it shows the page very quickly.
However, just clicking on a post can take 20 seconds before something happens.
If it's not something external doing this then it's your database running out of cache-memory, looks like your tables/indexes are too big to be stored into memory, as such take a long time to process.
Greeting Bas.
Re: Server update
Hi Bas,
For me everything looks fast, take less than 1s. Is a big server with 24GB of ram and a very small forum, so I don't expect to be a performance issue. Do you recommend me to check something specific?
Bas
Re: Server update
Post by Bas »
Check /etc/mysql/my.cnf
Set this:
# * Fine Tuning
key_buffer              = 1024M
max_allowed_packet      = 16M
thread_stack            = 512K
thread_cache_size       = 192
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched
max_connections        = 500
table_cache            = 256
thread_concurrency     = 10
# * Query Cache Configuration
query_cache_limit       = 2M
query_cache_size        = 32M
By default these settings are very small, key_buffer could be just 8MB or 16MB and such a low setting will hinder all mysql databases small and big.
I have run many very big forums and if you don't change the defaults they will slow down to a crawl, like yours does.
If those settings won't solve it, you may have other problems.
Greetings Bas.
Re: Server update
I'm running Centos 7, with a different folder structure.
This is what I have in /etc/my.cnf
[mysqld]
datadir=/var/lib/mysql
socket=/var/lib/mysql/mysql.sock
[mysqld_safe]
log-error=/var/log/mariadb/mariadb.log
pid-file=/var/run/mariadb/mariadb.pid
# include all files from the config directory
!includedir /etc/my.cnf.d
Re: Server update
I'm still trying to understand what is slow here, because for me everything is very fast. Just give me an example.
Bas
Re: Server update
Post by Bas »
Every click takes 20 or more seconds....no matter what I do.
No clue why.....
Could be a firewall or whatever, but it's always the same....click and wait about 20 secs...
Bas
Re: Server update
Post by Bas »
Again 20sec...for a message to be posted...
