patch cord
kd0org
patch cord
Post by kd0org »
is it possible to run an audio patch cord from my transceivers headphone jack to my laptop's mic+speaker jacks? this would eliminate the problem of having the radio blaring unattended and having my laptop pickup room conversations.
Re: patch cord
Yes, you can connect an audio cable between your data port and your PC, as in a digimodes interface. That output provides a constant level audio.
To use audio from the data port during Tx, you need to use the PTT signal on the same connector, not through CAT or through the transceiver mic PTT.
