I first took the default confile file from the Icom repository.
CMD_SET_FILTER_WIDE=FE,FE,<A>,E0,1A,03,49,FD
CMD_SET_FILTER_MID=FE,FE,<A>,E0,1A,03,31,FD
CMD_SET_FILTER_NAR=FE,FE,<A>,E0,1A,03,22,FD
CMD_SET_MODE_LSB_WIDE=FE,FE,<A>,E0,04,00,01,FD
CMD_SET_MODE_USB_WIDE=FE,FE,<A>,E0,04,01,01,FD
CMD_SET_MODE_AM_WIDE=FE,FE,<A>,E0,04,02,01,FD
CMD_SET_MODE_CW_WIDE=FE,FE,<A>,E0,04,03,01,FD
CMD_SET_MODE_FSK_WIDE=FE,FE,<A>,E0,04,04,01,FD
CMD_SET_MODE_FM_WIDE=FE,FE,<A>,E0,04,05,01,FD
CMD_SET_MODE_CWR_WIDE=FE,FE,<A>,E0,04,07,01,FD
CMD_SET_MODE_RTTYR_WIDE=FE,FE,<A>,E0,04,08,01,FD
....and so on...
After that I modified it for myself:
CMD_SET_FILTER_WIDE=FE,FE,<A>,E0,26,00,00,00,01,FD,FE,FE,<A>,E0,1A,03,34,FD = BW 3,0 k
CMD_SET_FILTER_NOR=FE,FE,<A>,E0,26,00,00,00,02,FD,FE,FE,<A>,E0,1A,03,28,FD = BW 2,4 k
CMD_SET_FILTER_NAR=FE,FE,<A>,E0,26,00,00,00,03,FD,FE,FE,<A>,E0,1A,03,22,FD = BW 1,8 k
so far so good...
If I change now the filter, I also see in the scope (they picture entry no.4) the filter between 3.0 - 2.4 - 1.8 change.
But the display does NOT change, and FIL1 FIL2 FIL3 remains at the top of No. 2.
Then I have times to the parameter $ 26 dared.
Then changed times the Config as follows:
And lo and behold, the display now changes to FIL1, FIL2, FIL3
BUT !!!
Has a small beauty defect.
Unfortunately I find in the $ 26 no possibility as in the case of MODE Settings (without filter) 06.01 set.
Therefore, in this case, LSB is selected in the case of parameter no.2 (00)
I have now the following entry in my Config:
Has anyone solved the problem and a more elegant solution?
It may be worth mentioning that the other changes No. 1 and No. 3 are displayed IMMEDIATELY in the display.
Greetings from Germany
73 de DO1DI / Dieter
