Tnx Dan for quick replay...
yo3ggx wrote: ↑Wed Aug 29, 2018 4:09 pmCallsign window must appear immediately at first application start.
So if first start only - the window for entering the callsign will appear for a while and a black screen will appear
- after config direct CAT with my LAN if first start change freq. on my radio to 490 khz /LSB and 5W - in the earlier version, it probably was
At first connection, the app send a set of commands according with the default values for each option button. For subsequent starts, the latest status is set by sending the commands according with the latest status for each option button.
I understand that the radio starts with some default settings, I checked it and if we change the frequency, power and eg mode one time, then the next time this data is saved OK
- synchronize (freq) from Radio ----> APK it works very slowly the other side is ok
This depends on the number of commands added to the POLLING list and the baudrate between jAReC and the radio.
Bauddrate is set to 57600 as always and in other applications that work correctly, such as HRD - locally and RcForb - remotely
I don't understand this. You can see only one meter at one moment in time. You can select between WR, PWR, ALC and MOD (if defined in the config). You must check if the CMD_READ_PWR has the right format.
Power meter window is OK - it's about a window where the set power is shown, if I change in the application the radio will change, if I change into radio, in the window where the power is shown in the application does not change ... it is not something very important
- if set synchronize CMD_READ_SWR and put PTT I hear the beep in the radio speaker
I hear in radio speaker Beep...Beep...Beep...Beep... only if CMD_READ_SWR set but PTT works fine normally turns on and off
- The application works only once, I have to clear the memory to make it work again
Please detail. What do you mean by "work only once"?
I checked this more accurately and I noticed that it behaves if all the parameters are set to synchronize and if we turn off the radio using the Power button in the application, when the application is restarted and the radio is turned on, this button connects to the CAT and immediately closes the application and over and over again until you clear the memory and configure the entire program from the beginning.
I will write it more accurately ... because I checked again
If we set one parameter for synchronization is OK, if two or more and turn off the radio, the next time the application is turned on, but when the radio is turned on using the POWER button in the application - the application will stop working, it will close and you have to clear the data in the application settings.
SQ7OVT 73's
