Icom ic 7100
Niko
Icom ic 7100
Post by Niko »
I'm try the App over my ic7100.
I loaded the default version
  I've noticed that some keys don't work.
for example:
-mode does not work
  - 2 watt power does not work
-Filter does not work
-Amp - 20 Decibel does not work, there would also be filter2 which however does not exist in the key.
-agc does not work
- RepTone code does not work
-Tsql not all are working.
Then for example the Power button I would put next to the FN as a separate button
These problems I wanted to try to solve them, but in the free version I can't find the configuration file to edit it, if i can do it.
Thank you
Nicola
Re: Icom ic 7100
Hi Nicola,
In v3 you can transfer the configuration file to a PC through jAReC and edit it there, then import it back to Pocket RxTx. In this way you can easily backup your own configs. This is explained in the application user guide for both Pocket RxTx and jAReC.
Editing on the device is no more possible because the request for permission to read and write to external storage was removed.
Niko
Re: Icom ic 7100
Post by Niko »
Sorry than what you mean with V3.
I just tried several times to import the file configuration but without any success.
I press "cfg import-export" and "waiting for files transfer ..." appears but nothing happens.
We are talking about the free version??
Nicola
Re: Icom ic 7100
Hi Nicola,
Did you configured both ends (Pocket RxTx and jAReC) according to the user guides?
Yes, this feature is available in the free version too.
Niko
Re: Icom ic 7100
Post by Niko »
Yes Dan all configured, i already used the Android App on my cell, but i don' know why I'm not able to pickup the config file, to try correct the problem....
73 Nicola iw3gcr
Niko
Re: Icom ic 7100
Post by Niko »
Niko wrote: Sat Jun 01, 2019 6:39 pm Sorry than what you mean with V3.
Nicola
Yesssss Dan
import/export config file only working in pro Version. !!!!!!!!
Nicola
Niko
Re: Icom ic 7100
Post by Niko »
Hi Dan obviously bought the Pro version I can install it on two phones
Nicola
Niko
Re: Icom ic 7100
Post by Niko »
Incredible Dan I can't understand why we can't change mode,
the application thus conceived has enormous potential but something escapes me.
Nicola
Niko
Re: Icom ic 7100
Post by Niko »
Hi Dan I'm on the right track I'm studying ...
You could explain to me exactly the procedure to get the debug file, I read and reread but I can't ...
Another trick like import-export for the Pro version where I lost 2 days for nothing...
I'd like to give my contribution for the 3 ICOMs I have available,
But I need help ...
Thank you
73 Nicola
Re: Icom ic 7100
Hi Nicola,
If the post is still actual, please give me more details about what do you want to achieve.
