Yaesu 767gx support files
ki5szo
Post by ki5szo »
Would anyone have a support file for a yaesu 767gx? It does have cat cable support. It will operate from hdr but looking for the pocket ability.
Re: Yaesu 767gx support files
There is no config available yet for FT767GX, but based on the user guide from here:
http://www.iw2nmx.it/Yaesu/FT-767GX/FT- ... Manual.pdf
it looks like the protocol is similar with the one used by FT8x7 radios.
You can build the config starting from the FT857 config as a template.
ki5szo
Post by ki5szo »
i can not seem to find the 5=857 template. when i try to dl it from the program it says its not in the server.
Sorry for the late reply, but I didn't receive any notification about your reply and found it now when doing some cleanup in the forum.
FT857 config is not yet available. I'm in a very busy period and have no time to update all the configs, so I'm counting on users owning respective transceivers to help.
For the FT8x7 radios, only FT817 config v4 is available currently.
