Error EXCEPTION_ACCESS_VIOLATION (0xc0000005)
iu2idk
Post by iu2idk »
Good day,
I'm reporting this error here and not in bugs report section becaus I think that it is related to an error in my PC and not a bug in the software.
I'm trying to run JAReC 3.0 on a windows PC, with latest Java RE (8) installed.
Everything seems to work correctly, the background of the window is yellow while waiting for a connection, but as I connect to my station (being inside the same WiFi network) with PrxTx the window suddenly closes and JAReC creates a .txt file in its folder, indicating the following error:
EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000007110b5db, pid=13732, tid=0x0000000000001430
# JRE version: Java(TM) SE Runtime Environment (8.0_333-b02) (build 1.8.0_333-b02)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.333-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [jSSC-2.8_x86_64.dll+0xb5db]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x000002705c432000): JavaThread "JavaFX Application Thread" [_thread_in_native, id=5168, stack(0x000000a1f8800000,0x000000a1f8900000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000044f4be70
Registers:
RAX=0x0000000044f4be70, RBX=0x000000a1f88fce20, RCX=0x00007ff9acae4094, RDX=0x0000000000000000
RSP=0x000000a1f88fcdb0, RBP=0x000000a1f88fcf30, RSI=0x000002705c432200, RDI=0x0000000000000a94
R8 =0x000000a1f88fcca8, R9 =0x000000a1f88fcda0, R10=0x0000000000000000, R11=0x0000000000000246
R12=0x000000a1f88fcfe0, R13=0x00000270630a1690, R14=0x000000a1f88fcee0, R15=0x000002705c432000
RIP=0x000000007110b5db, EFLAGS=0x0000000000010202
Top of Stack: (sp=0x000000a1f88fcdb0)
0x000000a1f88fcdb0: 00000270630972f0 0000027044b70000
0x000000a1f88fcdc0: 000000007110b230 0000027044c90000
0x000000a1f88fcdd0: 000000a1f88fce90 0000000000000004
0x000000a1f88fcde0: 000002705c432200 0000000000000a94
0x000000a1f88fcdf0: 000000a1f88fcf30 0000000071112590
0x000000a1f88fce00: 000002705c432000 000000a1f88fcee0
0x000000a1f88fce10: 00000270630a1690 000000a1f88fcfe0
0x000000a1f88fce20: 00000270630a1690 00007ff9aca679e1
0x000000a1f88fce30: 00000270630a1680 0000027044c90000
0x000000a1f88fce40: 000000a1f88fcf30 0000000000000000
0x000000a1f88fce50: 0000000071113500 0000000071113be8
0x000000a1f88fce60: 000000a1f88fce90 0000000071112641
0x000000a1f88fce70: 000000a1f88fce00 000002705c432200
0x000000a1f88fce80: 0000000000000000 0000000000000000
0x000000a1f88fce90: 000000a1f88fcf30 0000000071101595
0x000000a1f88fcea0: 000000000000001c 0000027000000000
Instructions: (pc=0x000000007110b5db)
0x000000007110b5bb: c5 0f 1f 40 00 55 57 56 53 48 83 ec 28 48 8b 05
0x000000007110b5cb: 39 33 01 00 48 89 cb 48 85 c0 0f 84 c5 00 00 00
0x000000007110b5db: 8b 38 85 ff 0f 88 ab 00 00 00 48 8b 05 1c 33 01
0x000000007110b5eb: 00 48 85 c0 0f 84 bc 00 00 00 8b 30 85 f6 74 57
Register to memory mapping:
RAX=0x0000000044f4be70 is an unknown value
RBX=0x000000a1f88fce20 is pointing into the stack for thread: 0x000002705c432000
RCX=0x00007ff9acae4094 is an unknown value
RDX=0x0000000000000000 is an unknown value
RSP=0x000000a1f88fcdb0 is pointing into the stack for thread: 0x000002705c432000
RBP=0x000000a1f88fcf30 is pointing into the stack for thread: 0x000002705c432000
RSI=0x000002705c432200 is an unknown value
RDI=0x0000000000000a94 is an unknown value
R8 =0x000000a1f88fcca8 is pointing into the stack for thread: 0x000002705c432000
R9 =0x000000a1f88fcda0 is pointing into the stack for thread: 0x000002705c432000
R10=0x0000000000000000 is an unknown value
R11=0x0000000000000246 is an unknown value
R12=0x000000a1f88fcfe0 is pointing into the stack for thread: 0x000002705c432000
R13=0x00000270630a1690 is an unknown value
R14=0x000000a1f88fcee0 is pointing into the stack for thread: 0x000002705c432000
R15=0x000002705c432000 is a thread
Stack: [0x000000a1f8800000,0x000000a1f8900000], sp=0x000000a1f88fcdb0, free space=1011k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [jSSC-2.8_x86_64.dll+0x12590]
C [jSSC-2.8_x86_64.dll+0x1595]
C 0x000002704670a02e
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j jssc.SerialNativeInterface.openPort(Ljava/lang/String;Z)J+0
j jssc.SerialPort.openPort()Z+65
j anywheresoftware.b4j.serial.Serial.Open(Ljava/lang/String;)V+16
j ro.yo3ggx.jarec.jareccore._mycatsrvsocket_newconnection(ZLanywheresoftware/b4a/objects/SocketWrapper;)Ljava/lang/String;+175
v ~StubRoutines::call_stub
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+100
J 1793 C1 sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object; (10 bytes) @ 0x0000027046cd2884 [0x0000027046cd2780+0x104]
J 1792 C1 java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object; (62 bytes) @ 0x0000027046cd38ec [0x0000027046cd3500+0x3ec]
j anywheresoftware.b4a.BA.raiseEvent2(Ljava/lang/Object;ZLjava/lang/String;Z[Ljava/lang/Object;)Ljava/lang/Object;+76
j anywheresoftware.b4a.BA$3.run()V+39
j com.sun.javafx.application.PlatformImpl.lambda$null$5(Ljava/lang/Runnable;)Ljava/lang/Void;+1
j com.sun.javafx.application.PlatformImpl$$Lambda$50.run()Ljava/lang/Object;+4
J 2274 java.security.AccessController.doPrivileged(Ljava/security/PrivilegedAction;Ljava/security/AccessControlContext;)Ljava/lang/Object; (0 bytes) @ 0x0000027046deca66 [0x0000027046deca00+0x66]
j com.sun.javafx.application.PlatformImpl.lambda$runLater$6(Ljava/lang/Runnable;Ljava/security/AccessControlContext;)V+7
j com.sun.javafx.application.PlatformImpl$$Lambda$49.run()V+8
J 2573 C1 com.sun.glass.ui.InvokeLaterDispatcher$Future.run()V (91 bytes) @ 0x0000027046ea2c8c [0x0000027046ea2b80+0x10c]
j com.sun.glass.ui.win.WinApplication._runLoop(Ljava/lang/Runnable;)V+0
j com.sun.glass.ui.win.WinApplication.lambda$null$4(ILjava/lang/Runnable;)V+8
j com.sun.glass.ui.win.WinApplication$$Lambda$38.run()V+12
j java.lang.Thread.run()V+11
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x000002705eea6800 JavaThread "Thread-10" daemon [_thread_blocked, id=13168, stack(0x000000a1f9900000,0x000000a1f9a00000)]
0x000002705eeaa000 JavaThread "Thread-9" daemon [_thread_blocked, id=5832, stack(0x000000a1f9800000,0x000000a1f9900000)]
0x000002705eea8000 JavaThread "Thread-8" daemon [_thread_in_native, id=7956, stack(0x000000a1f9700000,0x000000a1f9800000)]
0x000002705eea9800 JavaThread "Java Sound Event Dispatcher" daemon [_thread_blocked, id=6484, stack(0x000000a1f8a00000,0x000000a1f8b00000)]
0x000002705eea5000 JavaThread "Thread-6" daemon [_thread_blocked, id=11844, stack(0x000000a1f7600000,0x000000a1f7700000)]
0x000002705ebdf800 JavaThread "Thread-5" daemon [_thread_blocked, id=2604, stack(0x000000a1f7500000,0x000000a1f7600000)]
0x000002705ec12800 JavaThread "Thread-4" daemon [_thread_in_native, id=12924, stack(0x000000a1f7400000,0x000000a1f7500000)]
0x000002705effb000 JavaThread "pool-3-thread-1" daemon [_thread_blocked, id=6116, stack(0x000000a1f9400000,0x000000a1f9500000)]
0x000002705eedd800 JavaThread "Prism Font Disposer" daemon [_thread_blocked, id=14232, stack(0x000000a1f9300000,0x000000a1f9400000)]
0x000002705ea43800 JavaThread "Thread-3" daemon [_thread_in_native, id=11852, stack(0x000000a1f8c00000,0x000000a1f8d00000)]
0x000002705ea43000 JavaThread "JavaFX-Launcher" [_thread_blocked, id=13324, stack(0x000000a1f8d00000,0x000000a1f8e00000)]
=>0x000002705c432000 JavaThread "JavaFX Application Thread" [_thread_in_native, id=5168, stack(0x000000a1f8800000,0x000000a1f8900000)]
0x000002705c424000 JavaThread "Thread-1" daemon [_thread_blocked, id=13784, stack(0x000000a1f8700000,0x000000a1f8800000)]
0x000002705c3d9800 JavaThread "QuantumRenderer-0" daemon [_thread_blocked, id=13192, stack(0x000000a1f8600000,0x000000a1f8700000)]
0x000002705b54d800 JavaThread "Service Thread" daemon [_thread_blocked, id=9200, stack(0x000000a1f8400000,0x000000a1f8500000)]
0x000002705b4d2000 JavaThread "C1 CompilerThread2" daemon [_thread_blocked, id=13572, stack(0x000000a1f8300000,0x000000a1f8400000)]
0x000002705b4c3800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=13568, stack(0x000000a1f8200000,0x000000a1f8300000)]
0x000002705b4bf000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=10876, stack(0x000000a1f8100000,0x000000a1f8200000)]
0x000002705b4bb800 JavaThread "Attach Listener" daemon [_thread_blocked, id=13576, stack(0x000000a1f8000000,0x000000a1f8100000)]
0x000002705b4ba800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=13580, stack(0x000000a1f7f00000,0x000000a1f8000000)]
0x000002705b4a6800 JavaThread "Finalizer" daemon [_thread_blocked, id=13604, stack(0x000000a1f7e00000,0x000000a1f7f00000)]
0x000002705ad74800 JavaThread "Reference Handler" daemon [_thread_blocked, id=13608, stack(0x000000a1f7d00000,0x000000a1f7e00000)]
0x0000027044cbf800 JavaThread "main" [_thread_blocked, id=13916, stack(0x000000a1f7700000,0x000000a1f7800000)]
Other Threads:
0x000002705b485000 VMThread [stack: 0x000000a1f7c00000,0x000000a1f7d00000] [id=13976]
0x000002705b56b000 WatcherThread [stack: 0x000000a1f8500000,0x000000a1f8600000] [id=12768]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
heap address: 0x0000000081c00000, size: 2020 MB, Compressed Oops mode: 32-bit
Narrow klass base: 0x0000000000000000, Narrow klass shift: 3
Compressed class space size: 1073741824 Address: 0x0000000100000000
Heap:
PSYoungGen total 38400K, used 26662K [0x00000000d5f00000, 0x00000000d8980000, 0x0000000100000000)
eden space 33280K, 65% used [0x00000000d5f00000,0x00000000d74403d0,0x00000000d7f80000)
from space 5120K, 95% used [0x00000000d7f80000,0x00000000d8449710,0x00000000d8480000)
to space 5120K, 0% used [0x00000000d8480000,0x00000000d8480000,0x00000000d8980000)
ParOldGen total 87552K, used 16K [0x0000000081c00000, 0x0000000087180000, 0x00000000d5f00000)
object space 87552K, 0% used [0x0000000081c00000,0x0000000081c04000,0x0000000087180000)
Metaspace used 19316K, capacity 20478K, committed 20736K, reserved 1067008K
class space used 2823K, capacity 3059K, committed 3072K, reserved 1048576K
Card table byte_map: [0x0000027055ab0000,0x0000027055eb0000] byte_map_base: 0x00000270556a2000
Marking Bits: (ParMarkBitMap*) 0x000000005b699030
Begin Bits: [0x0000027056160000, 0x00000270580f0000)
End Bits: [0x00000270580f0000, 0x000002705a080000)
Polling page: 0x0000027044e20000
CodeCache: size=245760Kb used=9015Kb max_used=9015Kb free=236744Kb
bounds [0x00000270466f0000, 0x0000027046fd0000, 0x00000270556f0000]
total_blobs=3623 nmethods=2919 adapters=616
compilation: enabled
Compilation events (10 events):
Event: 245.837 Thread 0x000002705b4d2000 2918 3 com.sun.javafx.collections.NonIterableChange::getPermutation (8 bytes)
Event: 245.837 Thread 0x000002705b4d2000 nmethod 2918 0x00000270467fe890 code [0x00000270467fea00, 0x00000270467fed50]
Event: 245.837 Thread 0x000002705b4d2000 2917 3 javafx.scene.control.ListCell::getListView (11 bytes)
Event: 245.838 Thread 0x000002705b4d2000 nmethod 2917 0x0000027046800d90 code [0x0000027046800f20, 0x0000027046801370]
Event: 245.838 Thread 0x000002705b4d2000 2919 3 com.sun.javafx.css.BitSet::contains (63 bytes)
Event: 245.838 Thread 0x000002705b4d2000 nmethod 2919 0x0000027046817490 code [0x0000027046817620, 0x0000027046817b30]
Event: 245.839 Thread 0x000002705b4d2000 2920 3 javafx.scene.control.ListView::getItems (22 bytes)
Event: 245.839 Thread 0x000002705b4d2000 nmethod 2920 0x0000027046816e50 code [0x0000027046816fc0, 0x0000027046817350]
Event: 245.840 Thread 0x000002705b4d2000 2921 ! 3 java.util.zip.Inflater::ended (32 bytes)
Event: 245.841 Thread 0x000002705b4d2000 nmethod 2921 0x0000027046822e50 code [0x0000027046822fc0, 0x0000027046823398]
GC Heap History (2 events):
Event: 2.175 GC heap before
{Heap before GC invocations=1 (full 0):
PSYoungGen total 38400K, used 33280K [0x00000000d5f00000, 0x00000000d8980000, 0x0000000100000000)
eden space 33280K, 100% used [0x00000000d5f00000,0x00000000d7f80000,0x00000000d7f80000)
from space 5120K, 0% used [0x00000000d8480000,0x00000000d8480000,0x00000000d8980000)
to space 5120K, 0% used [0x00000000d7f80000,0x00000000d7f80000,0x00000000d8480000)
ParOldGen total 87552K, used 0K [0x0000000081c00000, 0x0000000087180000, 0x00000000d5f00000)
object space 87552K, 0% used [0x0000000081c00000,0x0000000081c00000,0x0000000087180000)
Metaspace used 15258K, capacity 16052K, committed 16128K, reserved 1062912K
class space used 2303K, capacity 2490K, committed 2560K, reserved 1048576K
Event: 2.184 GC heap after
Heap after GC invocations=1 (full 0):
PSYoungGen total 38400K, used 4901K [0x00000000d5f00000, 0x00000000d8980000, 0x0000000100000000)
eden space 33280K, 0% used [0x00000000d5f00000,0x00000000d5f00000,0x00000000d7f80000)
Deoptimization events (10 events):
Event: 244.759 Thread 0x000002705c432000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x0000027046dd2c54 method=com.sun.javafx.collections.VetoableListDecorator.size()I @ 4
Event: 244.760 Thread 0x000002705c432000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x0000027046dd2c54 method=com.sun.javafx.collections.VetoableListDecorator.size()I @ 4
Event: 244.766 Thread 0x000002705c432000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000027046ddae94 method=java.lang.StrictMath.floorOrCeil(DDDD)D @ 38
Event: 244.771 Thread 0x000002705c432000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000002704689eee8 method=java.lang.String.startsWith(Ljava/lang/String;I)Z @ 25
Event: 244.772 Thread 0x000002705c432000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000027046991df0 method=java.util.zip.InflaterInputStream.read([BII)I @ 69
Event: 244.776 Thread 0x000002705ea43800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000027046f82eb4 method=com.sun.javafx.tk.quantum.QuantumToolkit.postPulse()V @ 109
Event: 244.784 Thread 0x000002705c432000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000027046d8cc50 method=com.sun.javafx.css.StyleManager$CacheContainer.getStyleMap(I)Lcom/sun/javafx/css/StyleMap; @ 9
Event: 244.787 Thread 0x000002705c432000 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000027046f8cf64 method=javafx.scene.CssStyleHelper.transitionToState(Ljavafx/scene/Node;)V @ 632
Event: 244.791 Thread 0x000002705ea43800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x0000027046f81c8c method=com.sun.javafx.tk.quantum.QuantumToolkit.postPulse()V @ 109
Event: 244.804 Thread 0x000002705c432000 Uncommon trap: reason=class_check action=maybe_recompile pc=0x0000027046e4ef18 method=javafx.scene.Node.updateLocalToParentTransform()V @ 11
Classes redefined (0 events):
No events
Internal exceptions (10 events):
Event: 2.839 Thread 0x000002705c432000 Exception <a 'java/io/IOException'> (0x00000000d67c38e8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u333\2551\hotspot\src\share\vm\prims\jni.cpp, line 710]
Event: 2.839 Thread 0x000002705c432000 Exception <a 'java/io/IOException'> (0x00000000d67c3b40) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u333\2551\hotspot\src\share\vm\prims\jni.cpp, line 710]
Event: 2.839 Thread 0x000002705effb000 Exception <a 'java/net/SocketException': socket closed> (0x00000000d64df7d0) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u333\2551\hotspot\src\share\vm\prims\jni.cpp, line 737]
Event: 4.596 Thread 0x000002705effb000 Exception <a 'java/net/SocketException': socket closed> (0x00000000d64dfcb0) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u333\2551\hotspot\src\share\vm\prims\jni.cpp, line 737]
Event: 4.602 Thread 0x000002705effb000 Exception <a 'java/net/SocketException': socket closed> (0x00000000d64e0190) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u333\2551\hotspot\src\share\vm\prims\jni.cpp, line 737]
Event: 4.606 Thread 0x000002705effb000 Exception <a 'java/net/SocketException': socket closed> (0x00000000d64e0670) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u333\2551\hotspot\src\share\vm\prims\jni.cpp, line 737]
Event: 9.667 Thread 0x000002705c432000 Exception <a 'java/io/IOException'> (0x00000000d6dce070) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u333\2551\hotspot\src\share\vm\prims\jni.cpp, line 710]
Event: 9.667 Thread 0x000002705c432000 Exception <a 'java/io/IOException'> (0x00000000d6dce2f8) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u333\2551\hotspot\src\share\vm\prims\jni.cpp, line 710]
Event: 9.667 Thread 0x000002705c432000 Exception <a 'java/io/IOException'> (0x00000000d6dce550) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u333\2551\hotspot\src\share\vm\prims\jni.cpp, line 710]
Event: 9.667 Thread 0x000002705effb000 Exception <a 'java/net/SocketException': socket closed> (0x00000000d64e0b50) thrown at [C:\jenkins\workspace\8-2-build-windows-amd64-cygwin\jdk8u333\2551\hotspot\src\share\vm\prims\jni.cpp, line 737]
Events (10 events):
Event: 245.839 loading class jssc/SerialPort$EventThread
Event: 245.839 loading class jssc/SerialPort$EventThread done
Event: 245.839 loading class jssc/SerialPort$LinuxEventThread
Event: 245.839 loading class jssc/SerialPort$LinuxEventThread done
Event: 245.840 Executing VM operation: RevokeBias
Event: 245.840 Executing VM operation: RevokeBias done
Event: 245.840 loading class jssc/SerialPortTimeoutException
Event: 245.840 loading class jssc/SerialPortTimeoutException done
Event: 245.840 loading class jssc/SerialPortException
Event: 245.840 loading class jssc/SerialPortException done
Dynamic libraries:
0x00007ff70b960000 - 0x00007ff70b9a7000 C:\Program Files\Java\jre1.8.0_333\bin\javaw.exe
0x00007ff9aca40000 - 0x00007ff9acc49000 C:\Windows\SYSTEM32\ntdll.dll
0x00007ff9ab520000 - 0x00007ff9ab5dd000 C:\Windows\System32\KERNEL32.DLL
0x00007ff9aa560000 - 0x00007ff9aa8d9000 C:\Windows\System32\KERNELBASE.dll
0x00007ff9aae00000 - 0x00007ff9aaeae000 C:\Windows\System32\ADVAPI32.dll
0x00007ff9ab410000 - 0x00007ff9ab4b3000 C:\Windows\System32\msvcrt.dll
0x00007ff9ac7d0000 - 0x00007ff9ac86e000 C:\Windows\System32\sechost.dll
0x00007ff9aaf30000 - 0x00007ff9ab050000 C:\Windows\System32\RPCRT4.dll
0x00007ff9aabc0000 - 0x00007ff9aad6c000 C:\Windows\System32\USER32.dll
0x00007ff9aa300000 - 0x00007ff9aa326000 C:\Windows\System32\win32u.dll
0x00007ff9ab5e0000 - 0x00007ff9ab609000 C:\Windows\System32\GDI32.dll
0x00007ff9aa1e0000 - 0x00007ff9aa2f2000 C:\Windows\System32\gdi32full.dll
0x00007ff9aa140000 - 0x00007ff9aa1dd000 C:\Windows\System32\msvcp_win.dll
0x00007ff9a9f30000 - 0x00007ff9aa041000 C:\Windows\System32\ucrtbase.dll
0x00007ff999950000 - 0x00007ff999bf5000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.22000.120_none_9d947278b86cc467\COMCTL32.dll
0x00007ff9ab3d0000 - 0x00007ff9ab401000 C:\Windows\System32\IMM32.DLL
0x00007ff94ac60000 - 0x00007ff94ac75000 C:\Program Files\Java\jre1.8.0_333\bin\vcruntime140.dll
0x00007ff94abc0000 - 0x00007ff94ac5b000 C:\Program Files\Java\jre1.8.0_333\bin\msvcp140.dll
0x000000005aeb0000 - 0x000000005b711000 C:\Program Files\Java\jre1.8.0_333\bin\server\jvm.dll
0x00007ff9abdf0000 - 0x00007ff9abdf8000 C:\Windows\System32\PSAPI.DLL
0x00007ff9a7d50000 - 0x00007ff9a7d83000 C:\Windows\SYSTEM32\WINMM.dll
0x00007ff9a7d90000 - 0x00007ff9a7d9a000 C:\Windows\SYSTEM32\VERSION.dll
0x00007ff9991d0000 - 0x00007ff9991d9000 C:\Windows\SYSTEM32\WSOCK32.dll
0x00007ff9ac990000 - 0x00007ff9ac9ff000 C:\Windows\System32\WS2_32.dll
0x00007ff9a9030000 - 0x00007ff9a9048000 C:\Windows\SYSTEM32\kernel.appcore.dll
0x00007ff94bef0000 - 0x00007ff94bf00000 C:\Program Files\Java\jre1.8.0_333\bin\verify.dll
0x00007ff94ab90000 - 0x00007ff94abbb000 C:\Program Files\Java\jre1.8.0_333\bin\java.dll
0x00007ff94ab70000 - 0x00007ff94ab88000 C:\Program Files\Java\jre1.8.0_333\bin\zip.dll
0x00007ff9ab620000 - 0x00007ff9abdcf000 C:\Windows\System32\SHELL32.dll
0x00007ff9a80a0000 - 0x00007ff9a8908000 C:\Windows\SYSTEM32\windows.storage.dll
0x00007ff9ab050000 - 0x00007ff9ab3c8000 C:\Windows\System32\combase.dll
0x00007ff9a7f30000 - 0x00007ff9a8096000 C:\Windows\SYSTEM32\wintypes.dll
0x00007ff9ac870000 - 0x00007ff9ac95a000 C:\Windows\System32\SHCORE.dll
0x00007ff9aaa80000 - 0x00007ff9aaadd000 C:\Windows\System32\shlwapi.dll
0x00007ff9a9e60000 - 0x00007ff9a9e81000 C:\Windows\SYSTEM32\profapi.dll
0x0000027044e90000 - 0x0000027044e93000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-console-l1-1-0.dll
0x0000027044ea0000 - 0x0000027044ea3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-console-l1-2-0.dll
0x0000027044eb0000 - 0x0000027044eb3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-datetime-l1-1-0.dll
0x0000027044ec0000 - 0x0000027044ec3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-debug-l1-1-0.dll
0x0000027044ed0000 - 0x0000027044ed3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-errorhandling-l1-1-0.dll
0x0000027044ee0000 - 0x0000027044ee4000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-file-l1-1-0.dll
0x0000027044ef0000 - 0x0000027044ef3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-file-l1-2-0.dll
0x0000027044f00000 - 0x0000027044f03000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-file-l2-1-0.dll
0x0000027044f10000 - 0x0000027044f13000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-handle-l1-1-0.dll
0x0000027044f20000 - 0x0000027044f23000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-heap-l1-1-0.dll
0x0000027044f30000 - 0x0000027044f33000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-interlocked-l1-1-0.dll
0x000002705c4a0000 - 0x000002705c4a3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-libraryloader-l1-1-0.dll
0x000002705c4b0000 - 0x000002705c4b3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-localization-l1-2-0.dll
0x000002705c4c0000 - 0x000002705c4c3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-memory-l1-1-0.dll
0x000002705c4d0000 - 0x000002705c4d3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-namedpipe-l1-1-0.dll
0x000002705c4e0000 - 0x000002705c4e3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-processenvironment-l1-1-0.dll
0x000002705c4f0000 - 0x000002705c4f3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-processthreads-l1-1-0.dll
0x000002705c500000 - 0x000002705c503000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-processthreads-l1-1-1.dll
0x000002705c510000 - 0x000002705c513000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-profile-l1-1-0.dll
0x000002705c520000 - 0x000002705c523000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-rtlsupport-l1-1-0.dll
0x000002705c530000 - 0x000002705c533000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-string-l1-1-0.dll
0x000002705c540000 - 0x000002705c543000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-synch-l1-1-0.dll
0x000002705c550000 - 0x000002705c553000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-synch-l1-2-0.dll
0x000002705c560000 - 0x000002705c563000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-sysinfo-l1-1-0.dll
0x000002705c570000 - 0x000002705c573000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-timezone-l1-1-0.dll
0x000002705c580000 - 0x000002705c583000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-core-util-l1-1-0.dll
0x000002705c590000 - 0x000002705c593000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-conio-l1-1-0.dll
0x000002705c5a0000 - 0x000002705c5a4000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-convert-l1-1-0.dll
0x000002705c5b0000 - 0x000002705c5b3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-environment-l1-1-0.dll
0x000002705c5c0000 - 0x000002705c5c3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-filesystem-l1-1-0.dll
0x000002705c5d0000 - 0x000002705c5d3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-heap-l1-1-0.dll
0x000002705c5e0000 - 0x000002705c5e3000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-locale-l1-1-0.dll
0x000002705c5f0000 - 0x000002705c5f5000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-math-l1-1-0.dll
0x000002705c600000 - 0x000002705c605000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-multibyte-l1-1-0.dll
0x000002705c610000 - 0x000002705c620000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-private-l1-1-0.dll
0x000002705c620000 - 0x000002705c623000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-process-l1-1-0.dll
0x000002705c630000 - 0x000002705c634000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-runtime-l1-1-0.dll
0x000002705c640000 - 0x000002705c644000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-stdio-l1-1-0.dll
0x000002705c650000 - 0x000002705c654000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-string-l1-1-0.dll
0x000002705c660000 - 0x000002705c663000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-time-l1-1-0.dll
0x000002705c670000 - 0x000002705c673000 C:\Program Files\Java\jre1.8.0_333\bin\api-ms-win-crt-utility-l1-1-0.dll
0x00007ff94aa70000 - 0x00007ff94ab6a000 C:\Program Files\Java\jre1.8.0_333\bin\ucrtbase.dll
0x00007ff94aa60000 - 0x00007ff94aa6c000 C:\Program Files\Java\jre1.8.0_333\bin\vcruntime140_1.dll
0x00007ff94aa30000 - 0x00007ff94aa53000 C:\Program Files\Java\jre1.8.0_333\bin\prism_d3d.dll
0x00007ff953c50000 - 0x00007ff953df6000 C:\Windows\system32\d3d9.dll
0x00007ff9a73f0000 - 0x00007ff9a741f000 C:\Windows\SYSTEM32\dwmapi.dll
0x00007ff9a7360000 - 0x00007ff9a7398000 C:\Windows\SYSTEM32\dxcore.dll
0x00007ff9a7150000 - 0x00007ff9a71fc000 C:\Windows\system32\uxtheme.dll
0x00007ff953ae0000 - 0x00007ff953c43000 C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a086f01cc7be643a\igdumdim64.dll
0x00007ff9500d0000 - 0x00007ff953ad4000 C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a086f01cc7be643a\igd9dxva64.dll
0x00007ff9abe60000 - 0x00007ff9abffa000 C:\Windows\System32\ole32.dll
0x00007ff9aaae0000 - 0x00007ff9aabb6000 C:\Windows\System32\OLEAUT32.dll
0x00007ff9ac360000 - 0x00007ff9ac7cc000 C:\Windows\System32\SETUPAPI.dll
0x00007ff9a9b80000 - 0x00007ff9a9bcc000 C:\Windows\SYSTEM32\cfgmgr32.dll
0x00007ff99ffb0000 - 0x00007ff9a01ef000 C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a086f01cc7be643a\igdgmm64.dll
0x00007ff9a3f40000 - 0x00007ff9a3f84000 C:\Windows\SYSTEM32\directxdatabasehelper.dll
0x00007ff9a7500000 - 0x00007ff9a7534000 C:\Windows\SYSTEM32\ntmarta.dll
0x00007ff94a9e0000 - 0x00007ff94aa22000 C:\Program Files\Java\jre1.8.0_333\bin\glass.dll
0x00007ff9aa8e0000 - 0x00007ff9aa9cc000 C:\Windows\System32\COMDLG32.dll
0x00007ff9ac1d0000 - 0x00007ff9ac2ee000 C:\Windows\System32\MSCTF.dll
0x00007ff9aa0c0000 - 0x00007ff9aa13f000 C:\Windows\System32\bcryptPrimitives.dll
0x00007ff9583c0000 - 0x00007ff9583e7000 C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a086f01cc7be643a\igdinfo64.dll
0x00007ff99a7d0000 - 0x00007ff99d432000 C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_a086f01cc7be643a\igc64.dll
0x00007ff988f30000 - 0x00007ff988f44000 C:\Program Files\Java\jre1.8.0_333\bin\javafx_font.dll
0x00007ff993110000 - 0x00007ff99336f000 C:\Windows\SYSTEM32\dwrite.dll
0x00007ff9a5680000 - 0x00007ff9a568d000 C:\Program Files\Java\jre1.8.0_333\bin\jsound.dll
0x00007ff98dec0000 - 0x00007ff98decd000 C:\Program Files\Java\jre1.8.0_333\bin\jsoundds.dll
0x00007ff983150000 - 0x00007ff9831f2000 C:\Windows\SYSTEM32\DSOUND.dll
0x00007ff9800c0000 - 0x00007ff980171000 C:\Windows\SYSTEM32\ResampleDmo.DLL
0x00007ff9a9d50000 - 0x00007ff9a9d9d000 C:\Windows\SYSTEM32\powrprof.dll
0x00007ff97ab10000 - 0x00007ff97ab39000 C:\Windows\SYSTEM32\winmmbase.dll
0x00007ff998da0000 - 0x00007ff998dab000 C:\Windows\SYSTEM32\msdmo.dll
0x00007ff9a9c40000 - 0x00007ff9a9c53000 C:\Windows\SYSTEM32\UMPDC.dll
0x00007ff99fbf0000 - 0x00007ff99fc8c000 C:\Windows\SYSTEM32\MMDevAPI.DLL
0x00007ff97aac0000 - 0x00007ff97ab06000 C:\Windows\SYSTEM32\wdmaud.drv
0x00007ff988b90000 - 0x00007ff988b99000 C:\Windows\SYSTEM32\ksuser.dll
0x00007ff9a3f90000 - 0x00007ff9a3f9b000 C:\Windows\SYSTEM32\AVRT.dll
0x00007ff9a9bd0000 - 0x00007ff9a9bfc000 C:\Windows\SYSTEM32\DEVOBJ.dll
0x00007ff991d00000 - 0x00007ff991ed5000 C:\Windows\SYSTEM32\AUDIOSES.DLL
0x00007ff993f40000 - 0x00007ff993f4d000 C:\Windows\SYSTEM32\msacm32.drv
0x00007ff993f20000 - 0x00007ff993f3e000 C:\Windows\SYSTEM32\MSACM32.dll
0x00007ff993f10000 - 0x00007ff993f1b000 C:\Windows\SYSTEM32\midimap.dll
0x00007ff9aa9d0000 - 0x00007ff9aaa7f000 C:\Windows\System32\clbcatq.dll
0x00007ff997840000 - 0x00007ff9979c8000 C:\Windows\System32\Windows.UI.dll
0x00007ff981020000 - 0x00007ff98103c000 C:\Program Files\Java\jre1.8.0_333\bin\net.dll
0x00007ff9a9460000 - 0x00007ff9a94c7000 C:\Windows\system32\mswsock.dll
0x00007ff9a8b60000 - 0x00007ff9a8b8d000 C:\Windows\SYSTEM32\IPHLPAPI.DLL
0x00007ff9ac1c0000 - 0x00007ff9ac1c9000 C:\Windows\System32\NSI.dll
0x00007ff9a0f10000 - 0x00007ff9a0f29000 C:\Windows\SYSTEM32\dhcpcsvc6.DLL
0x00007ff9a1f40000 - 0x00007ff9a1f5e000 C:\Windows\SYSTEM32\dhcpcsvc.DLL
0x00007ff9a8bd0000 - 0x00007ff9a8cb8000 C:\Windows\SYSTEM32\DNSAPI.dll
0x0000000071100000 - 0x0000000071125000 C:\Users\User\.jssc\windows\jSSC-2.8_x86_64.dll
0x00007ff9a2060000 - 0x00007ff9a220e000 C:\Windows\SYSTEM32\WindowsCodecs.dll
VM Arguments:
java_command: C:\Users\User\Downloads\jAReC_v3.0.jar
java_class_path (initial): C:\Users\User\Downloads\jAReC_v3.0.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\dotnet\;C:\Users\User\AppData\Local\Microsoft\WindowsApps;
USERNAME=User
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 78 Stepping 3, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 11 , 64 bit Build 22000 (10.0.22000.675)
CPU:total 4 (initial active 4) (2 cores per cpu, 2 threads per core) family 6 model 78 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, rtm, 3dnowpref, lzcnt, ht, tsc, tscinvbit, bmi1, bmi2, adx
Memory: 4k page, physical 8269400k(3911344k free), swap 10235480k(4233972k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.333-b02) for windows-amd64 JRE (1.8.0_333-b02), built on Apr 25 2022 22:49:11 by "java_re" with MS VC++ 15.9 (VS2017)
time: Sun May 22 16:59:00 2022
timezone: ora legale Europa occidentale
elapsed time: 246.089921 seconds (0d 0h 4m 6s)
I've tried all the solutions on google, but currently I'm still not able to have JAReC correctly working.
Thanks in advance for the help
