Local KiwiSDR integration?
dwadi
Post by dwadi »
I have question if you have any plan to integrate option to easy add own local KiwiSDR server to app?
Re: Local KiwiSDR integration?
Currently I have no plans to integrate local KiwiSDR, only RTLSDR, but on the wish list is OpenWebRX support.
filip
son est saccadé
Post by filip »
Bonjour,
Merci pour application qui fonctionne sur FTDX 10 mais en 4ou 5G le son est saccadé et même indécodable.
De ce fait je l'utilise en WIFI chez moi je ne peux pas l'utilise a l’extérieur de mon QRA.
il a t'il une solution pour éviter les saccade en 4 ou 5G
Merci Philip
This means the connection quality is not so good. As my app in the current version use the simple uLaw codec, you cannot do to much to improve it. In the next release, variable bitrate Opus codec will be used.
Are you using audio over TCP or UDP?
P.S. Please open a new thread if you change the subject of the current one.
