jarec 3 crashing by connecting
pd1im
Post by pd1im »
i had jarec 3 running on my old PC without problems. now i have a new PC , instald everything new and jarec start as normal but when i try to connect it over pocket RXTX jarec crash and shut of. what do i (or PC) wrong? java version is 8 update 391
Re: jarec 3 crashing by connecting
I have similar problems when trying to use yaesu ft-857 and android phone. pocketrxtx crashes if the s-meter setting is on, and there are many other problems. Sometimes I can't get more than a few watts from the radio with ssb, and when I store different frequencies in the memory locations, they don't always work, there are also many other problems. With previous old versions, ft857 worked without major problems. I first suspected that there was a problem with my own devices, so I tested with another similar program, RC FORB CLIENT, remotehams. It works perfectly, so the problem must be in this V.4.2 program. Are older versions available somewhere? is the jarec5 version coming?
As an addition, now I noticed that when I install Darek from network mode, the radio control works, it should be jarec. It works normally in Icom, but ft-857 doesn't work as it should.
