hello Dan,
i would like to create a config file for my TS950SDX. therfore i don't know how to handle the commands.
i started from TS2000 config file. frequence change is working as it with this config file but not PTT as example or other commands
i don't know how to complete as example
SET_PTT=
READ_PTT=
PAT_PTT=
as example RX and TX commands for TS950SDX are "TX;" and "RX;" respectivly, so really different compared to TS2000 commands. SET_PTT={OFF=<SRX>;ON=<STX0>;},<S;>
or frequency Change for TS950 is FA00007100000;MD1; vs PAT_FREQ=<SF>,{VFO:<SA0>=VFO-A;<SB0>=VFO-B;},{FREQ:<C9><C8><C7><C6><C5><C4><C3><C2><C1><C0>;},<S;> for TS2000
or filter range FL005010;
Dan can you please help me to start the config file? i will share it after on the forum for the interested peoples.
best regards
73 Cedric F4JGI
TS950SDX config
Re: TS950SDX config
you can have a look to the generic_usdr config file. As I see, that the truesdx uses the TS480 protocol which may better for the ts850sdx.
SET_PTT={OFF=<S;RX;RX;RX;>;ON=<STX0;>;}
Well - I have the ts590s and maybe my colleague the ts890 - it will make a lot of sense, to have kenwood within tha jarec program.
73 Peter DF1LX
73 Peter DF1LX
