Page 2 of 2
Re: miniVNA Pro support
Posted: Wed Dec 05, 2012 8:47 pm
Hi Ferdinand,
When did you got that error message?
Please specify the steps from the moment you start the application.
I cannot replicate this behavior here.
Posted: Fri Dec 07, 2012 9:55 pm
by pd9mvr
This happened when logging in first time. Asked to calibrate, step 1.
Got my MiniVNA Pro today. Works like a charm on laptop. Wanted to try it out on mobile phones, unfortunately without success.
Phones used: Samsung Galaxy S2 and S3.
Posted: Fri Dec 07, 2012 10:01 pm
Hi Ferdinand,
I suspect something happen with the config file and get cuorrupted.
When you are in the Startup screen, long press the START button to reset the config file and accept the operation.
Then exit the application and start it again.
You will need to select again the Bluetooth device after that.
Please come back with the result.
Posted: Fri Dec 07, 2012 11:05 pm
by pd9mvr
I tried what you proposed, without success, error code remains.
73 de Marco
Posted: Fri Dec 07, 2012 11:22 pm
Hi Marco,
You are using BlueVNA version 0.6 from Play Store or an older version?
Is very strange that you have the same problem on both S2 and S3.
Can you send me a screenshot of the startup screen?
Posted: Fri Dec 07, 2012 11:45 pm
by pd9mvr
I have again reset the settings and tried making screenshot on the S3, but pushed wrong and the 1st part of calibration went through.
Once that was done the other 2 went through as well.
Got my connection and was able to analyze my mobile 2m antenna.
Guess persistence is the keyword?
Regards Marco
Posted: Fri Dec 07, 2012 11:52 pm
by pd9mvr
Regards Marco
Posted: Sat Dec 08, 2012 12:53 am
Hi Marco,
Good to see that is working for you now.
Good luck.
Posted: Thu Jan 17, 2013 8:40 pm
by ZS1RS
You are starting to ask for the impossible....improve on what you have done.....maybe write a PC version...
seriously I am only a appy at this, only thing I can find that may be nice is to auto fill in the file name for conversion to another format...the file will then be easily referenced to the original .vec .
Have used it on a few of of my antenna's, and has been a huge pleasure to work with
Thanks a mil
Posted: Thu Jan 17, 2013 10:11 pm
There are several good and complex PC versions, so no need for another one...
This is just a small app to be used in a very portable mode, a good match in my opinion for a displayless device like miniVNA.
