Unfortunately bad news from my tests.
1. first test was setting host pc in server mode and my local laptop as client with headphones.
RESULTS: a) i got audio back and forth from my laptop headset to the host pc
b) in first attempt to connect it wasn't able to so i had to start over again and try 2nd attempt
c) after connecting to host pc i listen to audio but no visuals on the server and client either - cannot see which band i am, frequency et.c
d) button PTT LOCK is missing the release function (via code i guess) so when we press it again it should stop PTT
2. second test was the direct mode only from the host pc
RESULTS: have exactly the same issue like result c) on first test. Cannot see which mode i am, which frequency, any of other settings of radio... just nothing. Only the needle of the meter i could see.
3. third and final test was server mode (v3) so i could see how pocket-rxtx works
RESULTS: works really well in that mode and from Pocket-RXTX i was able to fully control my radio.
Here is a demo video of my first 2 tests. Dan keep in mind that on the left side is the remote pc which i control via VNC and the right side, is Jarec in client mode.
https://www.iplayradio.net/cdn/files/pu ... -v4b10.mp4
73s, Jimmy.
